09-26-2010 03:06 AM - edited 03-06-2019 01:11 PM
Hello.
I have followed the Cisco guide on resetting a Cisco Router running IOS. everything was fine. i just don't know if there's anything of the old configuration left. the router used to be a ISP router accompanying a broadband subscription from (DK).
I have also added some old HP EDO RAM i had laying around. 8 Meg.
This is the output from the router booting up, plus a show version command:
System Bootstrap, Version 12.2(1r)XE2, RELEASE SOFTWARE (fc1)
TAC Support: http://www.cisco.com/cgi-bin/ibld/view.pl?i=support
Copyright (c) 2001 by cisco Systems, Inc.
C806 platform with 16384 Kbytes of main memory
program load complete, entry point: 0x80013000, size: 0x2b68b8
Self decompressing the image : ######################################################## [OK]
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
IOS (tm) C806 Software (C806-Y6-M), Version 12.2(8)T10, RELEASE SOFTWARE (fc1)
TAC Support: http://www.cisco.com/tac
Copyright (c) 1986-2003 by cisco Systems, Inc.
Compiled Fri 30-May-03 05:49 by kellythw
Image text-base: 0x80013170, data-base: 0x8055B664
CISCO C806 (MPC855T) processor (revision 0x301) with 14848K/1536K bytes of memory.
Processor board ID JAD05480VA9 (4137947577), with hardware revision 0000
CPU rev number 5
Bridging software.
2 Ethernet/IEEE 802.3 interface(s)
128K bytes of non-volatile configuration memory.
8192K bytes of processor board System flash (Read/Write)
2048K bytes of processor board Web flash (Read/Write)
--- System Configuration Dialog ---
Would you like to enter the initial configuration dialog? [yes/no]: no
þ
Press RETURN to get started!
00:00:06: %LINK-3-UPDOWN: Interface Ethernet0, changed state to up
00:00:06: %LINK-3-UPDOWN: Interface Ethernet1, changed state to up
00:00:07: %LINEPROTO-5-UPDOWN: Line protocol on Interface Ethernet0, changed state to up
00:00:07: %LINEPROTO-5-UPDOWN: Line protocol on Interface Ethernet1, changed state to up
00:00:15: %LINEPROTO-5-UPDOWN: Line protocol on Interface Ethernet1, changed state to down
00:00:28: %LINK-5-CHANGED: Interface Ethernet0, changed state to administratively down
00:00:28: %LINK-5-CHANGED: Interface Ethernet1, changed state to administratively down
00:00:29: %LINEPROTO-5-UPDOWN: Line protocol on Interface Ethernet0, changed state to down
00:00:29: %SYS-5-RESTART: System restarted --
00:00:29: %SNMP-5-COLDSTART: SNMP agent on host Router is undergoing a cold start
Router>show version
ROM: System Bootstrap, Version 12.2(1r)XE2, RELEASE SOFTWARE (fc1)
Router uptime is 1 minute
System image file is "flash:c806-y6-mz.122-8.T10.bin"
CPU rev number 5
Bridging software.
Configuration register is 0x2142
Router>
Can somebody please based on this tell me if there's anything of the old configuration left and is the RAM recognized ?
09-26-2010 03:29 AM
Hello.
According to your post, your router has 16MB of DRAM, 8MB of Flash 2MB of which are allocated to Web Flash to run the Web configuration tool and runs the c806-y6-mz.122-8.T10.bin (IP) operating system. There's no leftovers from the old configuration.
Hope this helps.
09-26-2010 03:36 AM
Thanks. but what about the 8 Meg of EDO ram i have added ?
09-26-2010 03:38 AM
It recognizes 16. If the 8 you added was in addition to that, it is
not recognizing it, but if it had 8 and you added 8 then all is well.
09-26-2010 03:39 AM
In order to answer this please try shutting down the router, remove the HP memory chip and repost the output of the sh ver command once the router goes to the router> prompt.
09-26-2010 03:44 AM
Additionally, you forgot to change the configuration register back to 0x2102. It's left to 0x2142. Follow the guideline from the configuration guide and change this too.
