How many endusers can a C2821(256MB RAM) support?
Answered Question
Sep 26th, 2010
I am working on a C2821 router need to know if it can support 300 plus endusers. The router will be used for forwarding Data to the internet. THANKS!
Correct Answer by paolo bevilacqua about 6 years 7 months ago
For such a low speed, you can even use a 2801. Note if you are buying new, a 2901 would be much better.
Overall Rating: 5 (1 ratings)
paolo bevilacqua Sun, 09/26/2010 - 08:35
  • Hall of Fame,
    Founding Member
Routers don't care about how many users you have.
What matter is the circuit speed. Which circuit spped do you have ?
Also, are you the end user trying to confirm what a cisco partner told you ?
toskie9999 Sun, 09/26/2010 - 08:46
by circuit speed do you mean our connection speed to the internet?? if it is our connection speed we have a dual 4mbps connection
Correct Answer
paolo bevilacqua Sun, 09/26/2010 - 09:37
  • Hall of Fame,
    Founding Member
toskie9999 Sun, 09/26/2010 - 10:09
ok thanks a lot you cleared my confusion hehehee. thanks for the advice
