How to alter the cos vaule on the frame switched by the c4500?
Sep 26th, 2010
Hi All,
I have the following topology:
DEVICE X <---- trunk vlan 10,20,30 ---->  in.p C4500 out.p <---- trunk vlan 10,20,30,40,50 ----> DEVICE Y
I need to change the cos value for specific vlan (vlan 20) on Catalyst 4500. But only for vlan 20.
Received cos vaule on input port of c4500 for vlan 20 is 0,
output cos value on output port of c4500 for vlan 20 have to be 5.
According documentation i need to set internal dscp, which have to be copied to the cos field on output port.
But it doesn't work as it is expected.
Any idea?
BR
jm.,
Jon Marshall Sun, 09/26/2010 - 10:32
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
jm
Might help if you can -
1) post config you are currently working with
2) specify IOS and supervisor model
In principle you should be able to match the vlan 20 traffic, mark it as CoS 5. You then need to look at the following maps -
CoS-to-DSCP - this map is used to determine which internal DSCP value is derived from your CoS value
DSCP-to-CoS - this map is used to determine the CoS value used on the outgoing interface and is derived from the internal DCSP value.
How are you verrifying it is not setting the correct value ?
Jon
jozef.mozolik Sun, 09/26/2010 - 10:56
HI,
1, config - pls. see below
2, Sup II+10GE 10GE (X2), 1000BaseX (SFP) WS-X4013+10GE    12.2(31r)SGA 12.2(50)SG3
I'm able to match vlan 20 traffic, but It's not possible to set the cos value, only the dscp or ip prec (on input).
jm.,
class-map match-any ANY
match any
policy-map P66
class ANY
  set ip dscp ef
class class-default
  set ip dscp ef
interface GigabitEthernet3/15
description c7600, g4/15
switchport trunk allowed vlan 10,20,30
switchport mode trunk
switchport nonegotiate
qos vlan-based
interface Vlan20
no ip address
service-policy input P66
class-map match-all CS0
match cos  0
class-map match-all CS1
match cos  1
class-map match-all CS2
match cos  2
class-map match-all CS3
match cos  3
class-map match-all CS4
match cos  4
class-map match-all CS5
match cos  5
class-map match-all CS6
match cos  6
class-map match-all CS7
match cos  7
policy-map TEST2
class CS0
  set dscp default
class CS1
  set dscp cs1
class CS2
  set dscp cs2
class CS3
  set dscp cs3
class CS4
  set dscp cs4
class CS5
  set dscp cs5
class CS6
  set dscp cs6
class CS7
  set dscp cs7
class class-default
interface GigabitEthernet3/16
description c7600, g4/16
switchport trunk allowed vlan 10,20,30,40,50
service-policy output TEST2
c4500-lab#show policy-map interface vl 20
Vlan20
  Service-policy input: P66
    Class-map: ANY (match-any)
      100 packets
      Match: any
        100 packets
      QoS Set
       ip dscp ef
    Class-map: class-default (match-any)
      0 packets
      Match: any
        0 packets
      QoS Set
       ip dscp ef
c4500-lab#
c4500-lab#sh policy-map interface g3/16
GigabitEthernet3/16
  Service-policy output: TEST2
    Class-map: CS0 (match-all)
      0 packets
      Match: cos  0
      QoS Set
       ip dscp default
    Class-map: CS1 (match-all)
      0 packets
      Match: cos  1
      QoS Set
       ip dscp cs1
    Class-map: CS2 (match-all)
      0 packets
      Match: cos  2
      QoS Set
       ip dscp cs2
    Class-map: CS3 (match-all)
      0 packets
      Match: cos  3
      QoS Set
       ip dscp cs3
    Class-map: CS4 (match-all)
      0 packets
      Match: cos  4
      QoS Set
       ip dscp cs4
    Class-map: CS5 (match-all)
      0 packets
      Match: cos  5
      QoS Set
       ip dscp cs5
    Class-map: CS6 (match-all)
      0 packets
      Match: cos  6
      QoS Set
       ip dscp cs6
    Class-map: CS7 (match-all)
      0 packets
      Match: cos  7
      QoS Set
       ip dscp cs7
      1686 packets
      Match: any
        1686 packets
Jon Marshall Sun, 09/26/2010 - 11:31
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
I can see what you are doing on the input ie. vlan based QOS for vlan 20 setting to DSCP value to 5. But what are you trying to do on the output interface with your policy map ?
Also -
1) can you post the output of "sh qos maps dscp to cos"
and can you confirm how you know the CoS value is not being set properly on the output queue ?
Jon
jozef.mozolik Sun, 09/26/2010 - 11:36
QOS map dscp to cos has default values
c4500-lab#show qos maps dscp cos
DSCP-CoS Mapping Table (dscp = d1d2)
d1 : d2  0  1  2  3  4  5  6  7  8  9
0 :    00 00 00 00 00 00 00 00 01 01
1 :    01 01 01 01 01 01 02 02 02 02
2 :    02 02 02 02 03 03 03 03 03 03
3 :    03 03 04 04 04 04 04 04 04 04
4 :    05 05 05 05 05 05 05 05 06 06
5 :    06 06 06 06 06 06 07 07 07 07
6 :    07 07 07 07
I'm checking the policy map on the output intf.
c4500-lab#show policy-map interface g3/16
GigabitEthernet3/16
      0 packets
      Match: cos  0
      QoS Set
       ip dscp default
      0 packets
      Match: cos  1
      QoS Set
       ip dscp cs1
      0 packets
      Match: cos  2
      QoS Set
       ip dscp cs2
      0 packets
      Match: cos  3
      QoS Set
       ip dscp cs3
      0 packets
      Match: cos  4
      QoS Set
       ip dscp cs4
      0 packets
      Match: cos  5
      QoS Set
       ip dscp cs5
      0 packets
      Match: cos  6
      QoS Set
       ip dscp cs6
      0 packets
      Match: cos  7
      QoS Set
       ip dscp cs7
      8608 packets
      Match: any
        8608 packets
JM.,
Jon Marshall Sun, 09/26/2010 - 11:41
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Is there any chance you can run a packet capture tool on device Y and check the CoS value there ?
Jon
jozef.mozolik Tue, 09/28/2010 - 13:35
Jon,
it is working as it is expected, cos remarking is done for IP traffic and non-IP traffic too (ARP packets). The only way how to check it was to configure local monitor session on c4500 (with 802.1q support) and to sniff traffic under linux/wireshark.
Thank You
BR
Jm.,
jozef.mozolik Wed, 09/29/2010 - 14:56
Hi All
applied configuration works well when the input port is on the linecard, IP traffic(icmp) and non-IP traffic (ARP) is remarked by cos=5 as it is expected.
But the same configuration is not working if the input port for vlan 20 is on the supervisor (Sup II+10GE), IP traffic is marked by cos=5, but the non-IP traffic has default cos value=0 (as it is received).
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:"Times New Roman"; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi;}
Any idea?
Thank You
BR
jm.,
jozef.mozolik Thu, 09/30/2010 - 02:41
Hi All,
by mistake I've omitted the line in the config /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:"Times New Roman"; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi;} qos map cos 0 to dscp 46, the result was - wrong conslusion. Finally the conclusion is:
- it's not possible to change COS value (example incomming cos=0, outgoing cos=5) using the configuration above for non-IP trafik (ARP packets)
- the only way how to do it, is to define qos trust cos on the input intf. and change the qos map: qos map cos 0 to dscp 46
jm.,
Related Content
