Peer Group on a Route Reflector
Answered Question
Sep 26th, 2010
Hi all experts.
I have 3 Routers connected in triangle.
R1 -> R2
R1 -> R3
All 3 routers are running bgp AS 10. R1 is serving as the route-reflector for R2 and R3. Following is the configuration i have done on R1
router bgp 10
bgp log-neighbor-changes
neighbor IBGP-RR-CLIENTS peer-group
neighbor IBGP-RR-CLIENTS remote-as 10
neighbor 12.0.0.2 peer-group IBGP-RR-CLIENTS
neighbor 13.0.0.3 peer-group IBGP-RR-CLIENTS
Now when i configure this
R1-RR(config-router)#neighbor 12.0.0.2 route-reflector-client
% Invalid command for a peer-group member
Why is this so ? what is the workaround instead of adding route-reflector-client command under peer group.
Kindly someone explain me the reason and also what shall i do to solve it.
Correct Answer by Jon Marshall about 6 years 6 months ago
Jonn.cos88 wrote:
Dear Jon,
Kindly dont apologize, its because of you guys and your help that i come here and ask my confusions. I dont have enough words to say thank you :-)
Now regarding the post, yes i know that i can apply it under peer group, but i dont want to, instead i want to apply it individually to neighbors. As you can see, its giving me error. Is it because that the outbound policy for all peer group members should be same ? is it because of this reason i am getting this error ?
Kindly guide me
Yes, it's because you have assigned that neighbor to a peer-group and so the attributes must be the same. If you want to only make one neighbor a route-reflector you can either -
1) don't assign that neighbor to a peer-group
or
2) do as KF suggested in this thread and have a separate peer-group that has the same attributes as the original peer-group but includes route-reflection
Jon
Correct Answer by Kostas Kyriakos about 6 years 6 months ago
Adding to what Jon Marshall suggested, in order to have just one peer reflecting routes you need to create a separate peer-group that does exactly that. Something like the following:
router bgp 10
neighbor IBGP-RR-CLIENTS route-reflector-client
neighbor IBGP-nonRR-CLIENTS peer-group
neighbor IBGP-nonRR-CLIENTS remote-as 10
neighbor 13.0.0.3 peer-group IBGP-nonRR-CLIENTS
Hope this helps.
Overall Rating: 5 (2 ratings)
Jon Marshall Sun, 09/26/2010 - 12:14
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
router bgp 10
Jon
the command should be -
By the way, apologies again for the misleading info on the "clear ip bgp x.x.x.x in" thread.
Jon
Jon Marshall Sun, 09/26/2010 - 12:18
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Jon
Just reread post - when you say -
are you saying you know you can apply it the way i have indicated and you don't want to ?
Jon
Jonn cos Sun, 09/26/2010 - 22:30
Dear Jon,
Kindly guide me
Correct Answer
Jon Marshall Mon, 09/27/2010 - 03:01
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Jonn.cos88 wrote:
Dear Jon,
Kindly guide me
or
Jon
Correct Answer
Kostas Kyriakos Sun, 09/26/2010 - 12:19
router bgp 10
Hope this helps.
