Cisco Systems VPN Client Version Errors
Sep 26th, 2010
Hello I am getting the following errors on my
VPN Connection Attempts
Copyright (C) 1998-2007 Cisco Systems, Inc. All Rights Reserved.
Client Type(s): Windows, WinNT
Running on: 5.1.2600 Service Pack 3
Config file directory: C:\Program Files\Cisco Systems\VPN Client\
1      19:59:14.375  09/26/10  Sev=Warning/3 CVPND/0xA340000D
The virtual adapter was not recognized by the operating system.
2      19:59:14.375  09/26/10  Sev=Warning/2 CM/0xE310000A
The virtual adapter failed to enable
3      19:59:14.531  09/26/10  Sev=Warning/2 IKE/0xE300009B
Failed to active IPSec SA: Unable to enable Virtual Adapter (NavigatorQM:936)
4      19:59:14.531  09/26/10  Sev=Warning/2 IKE/0xE30000A7
Unexpected SW error occurred while processing Quick Mode negotiator:(Navigator:2238)
Jennifer Halim Sun, 09/26/2010 - 17:31
Which Operating System is your Windows machine?
Also, is it 32-bit or 64-bit?
Has the same VPN Client software worked on the same machine before? has there been any change on your PC?
Jennifer Halim Sun, 09/26/2010 - 18:02
Please kindly check the following readme for VPN Client version
The new client requires a kernel patch, KB952876, from Microsoft before installing first before installing the actual client.
Pls kindly check if you have kernel patch KB952876
