Change default username on Cisco 2960
damianrodriguez
Hi! It is possible to change de default username "admin" from Cisco 2960?
Ports  Model              SW Version              SW Image
WS-C2960-24TC-L    12.2(35)SE5             C2960-LANBASEK9-M
Nagaraja Thanthry
If you have console access, please try the following:
configure terminal
##### Create a new username/password pair ############
username priv 15 password
##### Configure HTTP access using local username ######
ip http authentication local
##### Configure telnet access using local username #####
line vty 0 4
login local
exit
If you want to delete a username, please use the following command:
no username
Hope this helps.
NT
I can not use the local login command.
Nagaraja Thanthry
Thanks for your help!!!! Perfekt!
