WAE https problem
Hi Friends
     I use ACNS (ce612-5.5.9.9) , and I use https redirect from C6500 .Generally it can work by below configuration on WAE Side.
      https proxy incoming 443
      wccp https-cache router-list-num 1
      wccp router-list 1 172.20.161.254
     However , I find the problem that when this equipment reboot , one command line has been lost "wccp https-cache router-list-num 1" and I have to maunaully add this command for https.
     I would like to know how I can fix this issue
Thank you
Kamol
ahskhan
  Is this device managed by a CDM? if so can you check on the CDM if WCCP configurations are present and if / or overwritten by another group. If not please review your
errorlog/cli-errorlog.current file after the reboot and see where do you see "no wccp https-cache router-list-num 1".
Let me know if this helps.
Ahsan
Hi Ahsan
   Thank you for your  reply ,We don't have a CDM on the network. let me check the log file and let you know.
  After we check on local1/errorlog/cli-errorlog.current , I don't see "no wccp https-cache router-list-num 1" ,as you refer.
Kamol
Message was edited by: Kamol Pranweerapaiboon
