ACS 5.1 Shell Profiles
Sep 26th, 2010
Dear Friends,
I need your help in clarifying the conceptual doubt. I am not able to understand the difference between the following in ACS 5.1
Shell Profiles
Command Sets
I found this under POLICY ELEMENTS > AUTHORIZATION & PERMISSION > DEVICE ADMINISTRATION >
Please clarify the difference between these 2 elements and how it is used
regards,
SAIRAM
Overall Rating: 5 (1 ratings)
jrabinow Sun, 09/26/2010 - 22:10
  • Cisco Employee,
Using TACACS+ there are permissions that are defined when the se
ssion is authorized and can also be per command level authorization.
When the session is authorized (user logs in to a device) the permissions defined in the shell profile are applied; this includes items such as the privelege level
When the user enter commands at the device and performs per-command authorization, the command sets are applied
snarayanaraju Sun, 09/26/2010 - 23:30
Thanks for your time and sharing this valuable stuff. But i still not able to differentiate this.
If you can spend some more time, would you please explain this with example. Like when a user login to device when the "shell profile" is used and when the "command sets" is used.
Also, in which scenario "shell profile" is used and in which case ""command sets" are used.
I googled enough and tired
regards,
SAIRAM
