FTP is not working over WAN ipsec encryption link
Sep 26th, 2010
Hello all,
I have a pair of router connected via lease line. FTP is working fine (putting and getting file) from ftp server before encryption was implemented.
Attach router-A and router-B configuration.
Access-list 103 are for traffics between both site (it works fine before enccryption).
Access-list 100 added for ipsec purpose, where allow all traffics.
I have no idea why the getting of file from FTP is not working after encryption are implemented, while putting of files to ftp server works fine !?
Please advice what is the possiblity cause? and way to troubleshooting.
Thanks.
Christopher
Diego Armando C... Mon, 09/27/2010 - 13:41
  • Bronze, 100 points or more
So of you remove the crypto map from the interface in both router everything works?
chris_tan Mon, 09/27/2010 - 17:57
yes, removed crypto map all works fine. any idea why ?
chris_tan Tue, 09/28/2010 - 03:12
anyone out there has any idea what is the problem here?
up till now, i still cannot found the issue.
Appreciate your advice.
Thanks.
