Cannot deleted some command on ASA 5500?
Sep 26th, 2010
Dear All,
some command on ASA 5500 i cannot delete some command as below:
HQ(config)# no tunnel-group 203.189.134.71 type ipsec-l2l
ERROR: % Invalid input detected at '^' marker.
ERROR: Use 'no tunnel-group 203.189.134.71 webvpn-attributes' to remove all webvpn attributes before removing this tunnel-group. 'clear configure tunnel-group 203.189.134.71' can also be used to remove the tunnel-group.
but on my configuration i do VPN site to site!!!
How can i delete this command as above?
any way, i would like to delet some command as below but it still show on my ASA.
when i type "no crypto map Outside_map 3 set security-association lifetime seconds 28800" it don't have any error, it mean that the command allow but when i show run it still come up again, so how can i delete those command ?
crypto map Outside_map 3 set security-association lifetime kilobytes 4608000
Best Regareds,
Rechard
Overall Rating: 5 (1 ratings)
Jennifer Halim Sun, 09/26/2010 - 21:13
  • Cisco Employee,
You can remove the complete tunnel-group command for 203.189.134.71 as follows:
For the crypto map configuration, if you only have those 2 lines that sets the lifetime, you can remove it via the following:
clear configure crypto map Outside_map 3
Hope that helps.
rechard_david Mon, 09/27/2010 - 00:10
Dear Jennifer,
thanks you for you command !!!
I rate 5 point to you!!!
