PAP2t dial setting
Hi guys.
I'm having problems with some setting on the PAP2t-eu.
I can't seem to find where i can put the settings for:
  • Dialling timeout
  • Ring timeout if no number is dialled
  • Ring timeout if incomplete number (does not match the dialplan
in the configfile.
I'm using xml as a template and it would be great it you could also reply with the correct xml attribute.
Thanks in advance.
fsegato71 Thu, 05/19/2011 - 00:46
Hello everybody,
parameters 'interdigit long timer' and 'interdigit short timer' instruct ATA how long to wait after the first digit has been entered.
However, which parameter control the waiting time from off-hook to first digit before playing reorder tone?
Francesco
Boris Knezovic Thu, 05/19/2011 - 01:10
Dial Time Planer is what you need and you will find it on Page 67 of the above manual.
Boris
Related Content
