Static NAT Drops the Packets on ASA 5520
Answered Question
Sep 26th, 2010
Hi Team,
I have just configred ASA 5520 and put it in production, and every thing seems to work except i can not access the hosts on the inside network from OUTSIDE.
When i run Packet Tracer command from ASDM it tells me NAT is an issue,  i have tried few comobinations but struggling to get it working and trying to work out what i might have missed.
OUTSIDE IP: x.x.x.196
Outside IP Ueseable Range provided by the SP: x.x.x.197,x.x.x.198, and so on
Configuraion
name 10.10.10.10 ABA-Pilot description ABA-Pilot Server
name 10.10.10.11 ABA-NAS description ABACisco NAS Device
name 192.168.0.0 dmz description DMZ LAN
name 10.10.10.0 inside description Inside LAN
name x.x.x.192 internet description Outside Network
name 10.100.100.0 managment description Managenet LAN
interface GigabitEthernet0/0
description Connection to the Internet
nameif outside
security-level 100
ip address x.x.x.196 255.255.255.240
interface GigabitEthernet0/1
description Inside Interface
nameif inside
security-level 0
ip address 10.10.10.254 255.255.255.0
access-list inside_access_in remark Access to Internet
access-list inside_access_in extended permit ip inside 255.255.255.0 any
access-list dmz_access_in remark Access to Internet
access-list dmz_access_in extended permit ip dmz 255.255.255.0 any
access-list outside_access_in extended permit icmp any host ABA-Pilot
access-list outside_access_in extended permit tcp any host ABA-NAS object-group DM_INLINE_TCP_1
access-list outside_access_in extended permit tcp any host ABA-Pilot object-group ABA-pilot
access-list outside_access_in remark Management Access from Outside
access-list outside_access_in extended permit tcp any interface outside object-group Management-Access
access-list outside_access_in extended permit ip any object-group DM_INLINE_NETWORK_1
pager lines 24
logging asdm informational
mtu outside 1500
mtu inside 1500
mtu dmz 1500
mtu management 1500
ip verify reverse-path interface outside
no failover
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
global (outside) 2 interface
nat (inside) 2 0.0.0.0 0.0.0.0 outside
nat (dmz) 2 dmz 255.255.255.0 outside
static (outside,inside) tcp ABA-Pilot 3389 x.x.x.198 3389 netmask 255.255.255.255
static (outside,inside) tcp ABA-Pilot https x.x.x.198 https netmask 255.255.255.255
static (outside,inside) tcp ABA-Pilot www x.x.x.198 www netmask 255.255.255.255
static (outside,inside) ABA-NAS x.x.x.197 netmask 255.255.255.255
access-group outside_access_in in interface outside
access-group inside_access_in in interface inside
access-group dmz_access_in in interface dmz
route outside 0.0.0.0 0.0.0.0 x.x.x.193 1
Any help greatly appriciated
Correct Answer by Jennifer Halim about 6 years 4 months ago
The following commands have been configured the other way round:
Please kindly remove the above and change it to the following:
static (inside,outside) tcp x.x.x.198 3389 ABA-Pilot 3389 netmask 255.255.255.255
static (inside,outside) tcp x.x.x.198 https ABA-Pilot https netmask 255.255.255.255
static (inside,outside) tcp x.x.x.198 www ABA-Pilot www netmask 255.255.255.255
static (inside,outside) x.x.x.197 ABA-NAS netmask 255.255.255.255
After the above changes, please clear the xlate: clear xlate
Also your "outside_access_in" the destination address should be the public ip address (NATed address), not the private ip address.
For example the following line:
It should be towards the public ip address (x.x.x.198), not the private IP (ABA-Pilot - 10.10.10.10)
Hope that helps.
Overall Rating: 5 (1 ratings)
Correct Answer
Jennifer Halim Sun, 09/26/2010 - 21:38
Hope that helps.
tariqmansoor Sun, 09/26/2010 - 21:47
Thanks for your Excellent Help on this, My issue has been resolved.
Cheers Again
