Using the " character in a to be executed command (EMM)
Answered Question
I ran against a small challange building a feature in a EMM based menu.
I would like to have an user to change the number dialed in a chat-script but the chat-script command uses the character " in it's command.
The same character " is also used to mark the beginning and the end in the <IOSExecCommand> and the <IOSConfigCommand>.
When executing the feature it give's an error message back stating: EMM TCL Error: extra characters after close-quot.
Which is not weird because there are a lot of " in the command line and normally you can put multiple command-lines in a single ExecCommand - or ConfigCommand line to mark the beginning and the end of a single command-line.
According to TCL language script you could write the character " as \" or \\" but neither one of them does the trick to make it work.
The ConfigCommand I want to execute looks like this:
<IOSConfigCommand>"no chat-script internet " "chat-script internet "" "ATDT*98*2#" TIMEOUT 60 CONNECT"</IOSConfigCommand>
Does anyone have an idea how to solve this?
I'm kind of stuck with it.
Kind regards,
Jorn van Riel
Correct Answer by Joe Clarke about 6 years 6 months ago
Instead of using IOSConfigCommand, use EmbeddedTCL instead.  For example:
    ios_config "no chat-script internet" {chat-script internet "" "ATDT*98*2#" TIMEOUT 60 CONNECT}
Overall Rating: 5 (1 ratings)
Correct Answer
Joe Clarke Mon, 09/27/2010 - 21:39
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Related Content
