MSS exceeded
Sep 27th, 2010
i have asa 5540 and we are copy file from remote location to local server, we got Log on asa thats below
Dropping TCP packet from outside: dest_ip to DMZ:Ip , reasone : MSS exceeded, MSS 1380, DATA 1480
What is the reason of exceed ?
We are able to login sucessfully.
Thanks and Regards
Mitang R Prajapati.
rmavila Mon, 09/27/2010 - 04:22
Hi Mitang,
You can please try the below :
Configure access-list to match the traffic and apply it in a policy map as follows :
pixfirewall(config)#access-list http-list2 permit tcp any any (or you can change the ACL to whatever traffic you want to allow the MSS for)
pixfirewall(config)#class-map http-map1
pixfirewall(config-cmap)#match access-list http-list2
pixfirewall(config)#tcp-map mss-map
pixfirewall(config-tcp-map)#exceed-mss allow
pixfirewall(config)#policy-map http-map1
pixfirewall(config-pmap)#class http-map1
pixfirewall(config-pmap-c)#set connection advanced-options mss-map
pixfirewall(config)#service-policy http-map1 interface outside
Do tell me how it goes.
mitang.prajapati Mon, 09/27/2010 - 20:21
Hello rahul,
thanks for support,
We are not allowed on ASA 5540 firewall to permit any any .
could you tell me what purpose of this configuration ?
rmavila Tue, 09/28/2010 - 05:59
Hi Mitang,
You can change the access-list as :
pixfirewall(config)#access-list http-list2 permit tcp host   host  .
The following will help you understand the configuration :
MSS exceeded :
To allow or drop packets whose data length exceeds the TCP maximum segment size set by the peer during a
three-way handshake, use the exceed-mss command in tcp-map configuration mode.
set connection advanced-options :
To specify advanced TCP connection options within a policy-map for a traffic class,
use the set connection advanced-options command in class mode.
To remove advanced TCP connection options for a traffic class within a policy map, use the no form of this command.
set connection advanced-options tcp-mapname no set connection advanced-options tcp-mapname
Do tell me if you need any further help.
Christopher.Hayre Wed, 09/29/2010 - 15:53
Just  another option, you can leverage the sysopt connection tcpmss command to increase the maximum segment size on a global level if desired.  Cisco sets the MSS for ASA down to 1380 largely because of it's role as a flexible appliance (ex. for VPN reasons).  When I do deployments for non-VPN purposes, I always bump my MSS size up to allow for full 1500 MTU.
