Route Wireless to RVS4000
Sep 27th, 2010
I have spent hours trying to get the wireless network that is built into the Netcomm NB9W ADSL router to communicate with the RVS4000 VPN router that I have recently purchased.
Everything else is fine, I can connect the ADSL through to the RVS4000, it is just that I can't seem to find the correct settings to route the wireless traffic to the rest of our LAN.
The Netcomm NB9W is set to use the range - The RVS4000 is connected to the ADSL gateway via a static IP of
The RVS4000 is set to use the range Our main file server is located at
I have tried many combinations of static routes, turning on dynamic routes etc so that the PCs connecting via the DHCP server on the Wireless network ( - 99) to communicate with the rest of the network and in particular with the file server at
I would be very grateful if someone could set me straight on the settings that I should have in place for the RVS4000 VPN and if possible the Netcomm NB9W.
Many thanks in advance
