Bonding in 878
Answered Question
Sep 27th, 2010
Re: bonding in 878
How can i know what is the real speed that synchronizing my bundle line with two shdsl 2M/2M? Add the output of sh controller dsl 0:
CPE251#sh controllers dsl 0
DSL 0 controller UP
Globespan xDSL controller chipset
Line Mode: Four Wire Standard
DSL mode: Trained with SHDSL Annex B
Frame mode: Utopia
Configured Line rate: 4096Kbps
Line Re-activated 1 times after system bootup
LOSW Defect alarm: ACTIVE
CRC per second alarm: ACTIVE
Line termination: CPE
Line 0 statistics
        Current 15 min counters
                CRC : 0 LOSW Defect : 0 ES : 0  SES : 0 UAS : 0
        Previous 15 min counters
        Current 24 hr counters
                CRC : 5 LOSW Defect : 0 ES : 5  SES : 0 UAS : 32
        Previous 24 hr counters
                CRC : 5 LOSW Defect : 0 ES : 5  SES : 0 UAS : 0
Line 1 statistics
                CRC : 0 LOSW Defect : 0 ES : 0  SES : 0 UAS : 32
Line-0 status
Chipset Version:  0
Firmware Version:  R4.2.1
Modem Status:  Data, Status 1
Last Fail Mode:  Failed during Carrier Detect status:0x1
Line rate:  2056 Kbps
Framer Sync Status: In Sync
Rcv Clock Status: In the Range
Loop Attenuation:  13.5 dB
Transmit Power:  14.5 dB
Receiver Gain:  27.7420 dB
SNR Sampling:  37.9860 dB
Receive HEC Error Count:  0
Line-1 status
Chipset Version:  0
Loop Attenuation:  13.1 dB
Receiver Gain:  27.420 dB
SNR Sampling:  38.9550 dB
Dying Gasp: Present
Thanks in advanced
Correct Answer by Paolo Bevilacqua about 6 years 3 months ago
Yes, it's working correctly.
Overall Rating: 5 (1 ratings)
emilio1973 Mon, 09/27/2010 - 06:13
Ok, but there are two lines "line rate: 2056". This means that it is working correctly (4M/4M)?
