09-27-2010 02:58 AM - edited 03-11-2019 11:45 AM
Hi, in ASA with dhcp-relay mode, is there a solution to obtain a different dhcp server for each vlan ?
thanks
rs
09-27-2010 04:26 AM
Here is what is supported on DHCP Relay on ASA:
http://www.cisco.com/en/US/docs/security/asa/asa82/configuration/guide/dhcp.html#wp1115812
You can not define each interface pair for DHCP client request interface and DHCP server relay interface.
09-27-2010 05:12 AM
Thank you, but I need to associate a different dhcp server pool for each ASA vlan, through ASA dhcp relay.
From the configuration doc, it seems that I cannot associate a pool of dhcp server to a single vlan, so the dhcp server pool created are generally configured for all vlan with active dhcp relay.
rs
09-27-2010 05:21 AM
Yes you are absolutely right. You can't configure specific dhcp server for a specific client request for DHCP relay feature on ASA.
