How many signatures IPS have
Sep 27th, 2010
Just a quick question: how many signatures IPS have by default? in IPS7.0.
I've noticed some versions with 4700 or 3700, any official number?
-Dave
Jennifer Halim Mon, 09/27/2010 - 03:52
  • Cisco Employee,
There is no official count of signatures as signatures keep getting added on each release of the signature update. There is signature update release almost every few days.
To check how many default signature your particular IPS has, you can go to the "sig0" section, and at the bottom of the page, it would advise how many default signatures are available, and how many are enabled by default.
Hope that answers your question.
lchance Tue, 09/28/2010 - 08:36
Question for Jennifer:
Does this trap indicate the IPS is not getting updates if it has been several days/few weeks sending these traps on the hour?
cidsErrorSeverity:= error
cidsErrorName:= 11
cidsErrorMessage:= No installable auto update package found on server
Jennifer Halim Tue, 09/28/2010 - 19:41
  • Cisco Employee,
That could mean a few things:
1) What is the current version of your IPS engine? E3 or E4? Signature update for E3 engine stops at sig479, and to get the latest signature update, you would need to upgrade the IPS engine to E4, as off today, the latest signature pack is sig515.
2) How are you performing the auto update? auto update through a server hosted internally or auto update directly from cisco.com?
If you are auto updating from an internal server, you might want to check the connectivity and/or if the latest update is available on the internal auto update server. If it's directly from cisco.com, then you want to check point 1 above.
lchance Thu, 09/30/2010 - 06:19
In my case it is E4 and it is set for updates from cisco.com.
