RV082 forwarding broadcast packets
I've an RV082 connected to a 3rd party firewall. I've been asked to get broadcast packets for a particulas UDP destination port, from a VLAN on that 3rd party f/w into our corporate LAN, which hangs off of the RV082. The vlan remains only on the 3rd party f/w, and the traffic is routed to the RV082.
So I need to find out if the RV082, running in Router mode, with SPI turned off (firewall off), can forward those packets ?
I can see it says it supports multicast, but I'm guessing it can't forward broadcast?
Ashley Georgeson Mon, 09/27/2010 - 04:22
You can do this on the Layer 3 interface (vlan interface if configured).
The ip helper command will forward certain udp broadcasts to the destination ip address - useful for dhcp/bootp/tftp etc.
If you require a non-standard port, I would use the ip directed-broadcast command in combination with an extended access-list list to limit the feature only to the required port.  After all routers drop broadcast traffic for a reason!
Hope that helps, Ash.
