09-27-2010 04:55 AM - edited 03-14-2019 06:35 AM
Dears,
every time when I tray to access to CRS using //appadmin ,, after when i enter the user name and the password this message appear
The Cisco JTAPI Client are inconsistent, Please go to Cisco JTAPI Resync in the Unified CM Telephony Subsystem to install the Cisco JTAPI Client
and white page appear .
i am use CRS 5.0.2 and call manager 7.1.5 ,I am trying to restart the server it not worked .
any one advise me please.
Solved! Go to Solution.
09-27-2010 06:31 AM
this only means that Cisco never tested the compatibility between these UCCX and CUCM versions, meaning it could or could not work... the only certain thing is that you won't received TAC support with this configuration.
It's good to hear all other functionality works, but the JTAPI version will probably always be inconsistent. The system compares the JTAPI version running on UCCX and CUCM. If Cisco never tested these versions, the UCCX will not have the CUCM JTAPI version in it's internal list of compatible version.
As a possible workaround, you can manually enter the JTAPI version in UCCX, to make the system believe it's running the correct version.
- To check the JTAPI running in CUCM, please go to Cisco Unified Reporting> Unified CM Component Version and View Details> look for the cm-jtapi-plugin.
- On UCCX, please open CET> look for the ClusterDependentConfig; double click on the first entry of the right side. From the second tab, you can enter the JTAPI Version there and restart the Node Manager.
FYI, i've never really try that with unsupported versions but I think that'll make the trick and will not show the error any more. I would do that on Lab servers only or during a maintenance window to revert the changes if something happens.
Pablo
09-27-2010 05:11 AM
Hello Rami,
You're getting this error because the JTAPI versions are not compatible, and this happens because UCCX 5.0(2) is not compatible with CUCM version 7.x. Please check comp matrix and you'll see that UCCX 5.0(2) supports to be integrated with CUCM 5.x or 6.x only:
http://www.cisco.com/en/US/products/sw/custcosw/ps1846/products_device_support_tables_list.html
Hopefully the error will go away as soon as you run compatible versions.
Hope that helps.
Pablo
09-27-2010 05:47 AM
thank you Pablo , but i wondering , its not compatabile but whay the IVR system is work properly , and after when I install the new Call Manager , i didnt feel any problem .
I installed the call manager before 2 month ago .
09-27-2010 06:31 AM
Pablo
