09-27-2010 05:35 AM - edited 02-21-2020 04:52 PM
Hi, can I configure ASA to have an unique IP for vpn remote-access for all internal vlansin ASA 8.2(x) ?
Apart for outside interface, where we use public IP for remote-access, we need to use the same ASA private IP for vpn remote-access coming from all internal vlans (i.e. like management-access for ssh).
thanks
rs
09-27-2010 11:57 AM
As far as I'm aware you can only terminate the IPsec VPN connections on the actual IP of the interface of the ASA.
You cannot have an spare IP (not belonging to an interface) and terminate the VPN there (like you can do on routers), because the crypto map needs to be applied to an interface and there's no mechanism to reference to another IP.
Unless something has changed recently that I'm now aware, it cannot be done.
Federico.
10-06-2010 02:18 AM
Ok, It's just a dns matter, vpn client utilize a name to reach the ASA vpn peer:
- for outside, the dns servers give the public IP
- for inside and many dmz ASA vlans, the internal dns server resolve that name with the inside ASA address and for vpn client on dmz we have problems.
thank you in advance
greatings
rs
