Multicast packets are always flooded to trunked vlan ports
Sep 27th, 2010
  • Cisco Employee,
I've some problems with configuring a catalyst 6506.
The setup is as follows:
On two ports from the switch (1/3 and 1/4) the same vlan 12 tagged multicast stream 230.0.0.12 is received; but the source address differs: on trunked port 1/3 the stream has src ip 10.10.10.10 and on trunked port 1/4 the stream has src 10.10.10.11.
On trunked port 1/7 there is a host that sends vlan 12 tagged IGMPv3 source specific reports to receive stream 230.0.0.12 but only from source 10.10.10.10.
The stream is always received 2 times by the host regardless of the host sends out IGMPv3 reports to receive the MC or not.
When an IGMPv3 report is send by the host this is tracked by the igmp snooper as follows:
test#show ip igmp snooping explicit-tracking vlan 12
Source/Group                    Interface       Reporter        Filter_mode
10.10.10.10/230.0.0.12          Vl12:Gi1/7      10.10.11.10     INCLUDE
test#
Is it possible to configure the switch in a way that when on trunked port 1/7 a vlan 12 tagged IGMPv3 report is received for mc 230.0.0.12 src 10.10.10.10 only that stream is forwarded?
Now the switch configuration is as follows:
test#show running-config
Building configuration...
Current configuration : 11811 bytes
upgrade fpd auto
version 12.2
service timestamps debug uptime
service timestamps log uptime
service counters max age 5
hostname test
enable secret 5 $1$AJVM$k3HazdPdSPiebS/14O7qM.
no aaa new-model
ip subnet-zero
ipv6 mfib hardware-switching replication-mode ingress
mls ip multicast flow-stat-timer 9
no mls flow ip
no mls flow ipv6
no mls acl tcam share-global
mls cef error action freeze
redundancy
mode sso
main-cpu
  auto-sync running-config
spanning-tree mode pvst
diagnostic cns publish cisco.cns.device.diag_results
diagnostic cns subscribe cisco.cns.device.diag_commands
vlan internal allocation policy ascending
vlan access-log ratelimit 2000
interface GigabitEthernet1/3
switchport
switchport trunk allowed vlan 10-20
switchport mode trunk
no ip address
interface GigabitEthernet1/4
switchport
no ip address
interface GigabitEthernet1/7
switchport
no ip address
interface GigabitEthernet1/48
switchport
switchport access vlan 200
switchport mode access
no ip address
interface Vlan1
no ip address
shutdown
interface Vlan12
ip address 12.12.12.12 255.255.255.0
ip igmp version 3
ip igmp snooping querier
interface Vlan200
ip address 10.50.201.185 255.255.252.0
ip default-gateway 10.50.200.1
ip classless
ip route 0.0.0.0 0.0.0.0 10.50.200.1
no ip http server
control-plane
dial-peer cor custom
line con 0
line vty 0 4
password Switch
no login
monitor session 1 source interface Gi1/15 , Gi1/17 , Gi1/27
monitor session 1 destination interface Gi1/35
no cns aaa enable
end
test#
Giuseppe Larosa Mon, 09/27/2010 - 11:34
  • Hall of Fame,
    Founding Member
Hello Tom,
what IOS image is running on the C6500?
on 12.2SXF  the igmp querier is limited to IGMP version 2
see
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SXF/native/configuration/guide/snooigmp.html#wp1069655
on 12.2SXH and later releases IGMP querier runs in IGMP version 3
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SX/configuration/guide/snooigmp.html#wp1069655
so IOS image counts
Hope to help
Giuseppe
ttimmers Wed, 09/29/2010 - 05:31
  • Cisco Employee,
Hello Giuseppe,
On the C6500 indeed IOS 12.2SXF was running.
I've upgraded the C6500 to IOS 12.2.SXH but the result is the same as with the 12.2SXF software.
I did a capture on the outgoing port and on that port every querier from a vlan sends out an IGMPv3 general query. When a device receives this query, it reply's with an IGMPv3 report. So I think IGMPv3 is supported.
I don't understand why the igmp snooper doesn't stop the flooding of all the MC packets when an IGMPv3 report is received.
Do you have clue?
Tom
