Hairpin Config on ASA with 8.3.x
Sep 27th, 2010
Greetings All...
I have just upgraded to to 8.3, and I decided to start on a clean config, So I did not migrate any of the configurations over.
I am configuring a hairpin on the outside for VPN users.
The VPN subnet is A.B.250.0/24
The Server Subnet is A.B.100.0/24
Assuming all the tunnel group, group policy and other VPN config is correct, is the following hairpin configuration correct?
same-security-traffic permit intra-interface
object network SERVER_LAN
subnet A.B.100.0
object network VPN_POOL
subnet A.B.250.0
nat (outside,inside) source static VPN_POOL VPN_POOL
nat (inside,outside) dynamic interface
nat (outside,outside) dynamic interface
Jitendriya Athavale Mon, 09/27/2010 - 06:35
that looks ok do you face any problem with that
also you can check the config yourself and see where you have gone wrong by using packet tracer, i would suggets you have implemented this try using packet tracer and see if the translation happens fine
