1841 / HWIC?
Answered Question
Sep 27th, 2010
I have an 1841 router that will need a HWIC added to it, but I am wondering if I need to update the IOS before it is recognized?
It is currently running c1841-adventerprisek9-mz.124-3.bin
Correct Answer by krahmani323 about 6 years 7 months ago
Hello Carl,
Depending on your HWIC I would check the compatibility matrix for Integrated Services Routers (1st and 2nd generation) and look if it is supported and what IOS version introduced support =>
https://www.cisco.com/en/US/prod/collateral/routers/ps10538/aag_c07_563807.pdf
Hope it helps.
Kind regards.
Karim
Overall Rating: 5 (1 ratings)
Carl Harbeck Mon, 09/27/2010 - 06:26
That was just what I needed, thank you very much Karim (I do need to update my IOS).
Best regards,
Carl
Related Content
