ASA 5580
Sep 27th, 2010
I wanted to find out if It is possible to  created a network groups for dmz hosts to access inside host with no service group. I just want to allow some perticular servers to communicate to inside.
ARMANDO ALVARADO Mon, 09/27/2010 - 08:27
So that I understand this correctly. You can use this and the servers in the dmz will still communicate with the inside host with its nat address. Correct.
I using the same inside address for the nat.  I forgot to mention that also sorry. This is going to be for a virtual enviroment. Just trying to secure the group.
Jennifer Halim Mon, 09/27/2010 - 21:40
Sorry, not very clear on what you are trying to achieve after the second post.
Are you trying to configure grouping so you can configure the access-list more effectively?
What version of ASA 5580 are you running?
Can you please share the topology and what exactly you are trying to achieve. Thanks.
