CUCM stop providing Outside Dial tone
robmas0871
i have a strange issue:
- i configured "Privide Outside Dial Tone" on a Route Pattern accessing PSTN.
- i had no Voice Gateways configured and the Outside Dial Tone worked well as i dialed "0" (eg: the Route Pattern is: 0.!)
- after i configured a Voice Gateway with a single QSIG port, i can't listen the Outside Dial Tone. (the call is working well...i can access PSTN and call external numbers)
My questions are:
- Is the Outside Dial Tone provided by CUCM or by Voice Gateway ( i supposed by CUCM because it worked without a gateway)
- can the Voice Gateway QSIG port affects Outside Dial Tone behaviour ?
Thank you,
Roberto
Jaime Valencia
The tone is provided by CUCM, most likely you have something else that overlapps with the 0 pattern or whatever you use for outside line.
Look at your route plan report, if there is something that does not have the "Provide dial tone" option within the possible options it won't be played.
ie a phone DN 0123
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Jaime Valencia
ie a phone DN 0123
java
java
