Jaime Valencia Mon, 09/27/2010 - 09:06
  • Cisco Employee,
  • Hall of Fame,
    2011
This configuration is untested by Cisco, however, if you configure a regular H323 integration between both systems it should work fine.
Are you facing issues?
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
nshoe18 Mon, 09/27/2010 - 11:24
I am facing issues getting MPE to pull users from CallManager......I thought I had it setup correctly but when I test the connection from MPE it tells me the CallManager is unavailable.
nshoe18 Mon, 09/27/2010 - 11:43
So I was able to get the axl stuff to test good, but when I try to login with a user that is on my CUCM it tells me that user does not exist. Also I setup my gateway and route pattern on CUCM and configured the H.323 stuff according to the documentation in the wiki but when I dial the number I assigned I just get a busy signal.
nshoe18 Mon, 09/27/2010 - 11:51
After looking at my gateway it does not appear to be registering with the MeetingPlace server.
