CUMA iPhone not available
Sep 27th, 2010
I am running CUMA 7.1(3) with the latest service release.  I have installed the latest .oar file and see that the iphone is available, althought it is grayed out.
However, when I activate a user I don't see the iphone as an available device under any of the carriers.  I went ahead and provisioend it as a Windows Mobile phone using AT&T/Cingular and the CUMC on the iphone does connect.
Is this the way the iphone should be deployed or should I be able to select the iphone?
Manish
htluo Mon, 10/04/2010 - 12:09
  • Red, 2250 points or more
What version of CUMC are you using on iPhone?
7.x works with CUMA while 8.x works with CUCM directly.
Just FYI, CUMA server will be discontinued.  Thus I recommend use 8.x client with CUCM.
Michael
http://htluo.blogspot.com
