%ASA-4-313005: No matching connection for ICMP error message:
manik.palekar
Hello Frdz ...
I have NTP server in DMZ zone and all Inside hosts would get syn with DMZ zone NTP server ..
I have been getting huge No matching connection for ICMP error message between inside host and DMZ NTP server ....
Could you please suggest how to stop this messages ...
Regards ..
Manik Palekar
Jennifer Halim
Here is what syslog# 313005 means:
http://www.cisco.com/en/US/docs/security/asa/asa80/system/message/logmsgs.html#wp4771130
You might want to check why you are getting that particular ICMP error messages and who is sending it (ie: the inside host or the DMZ server) so the icmp error messages can be stopped.
Hi Jennifer ....
Thanks for the details ..at present these icmp requests are being blocked by Firewall due to No matching connection or there is no exiting icmp session .This results in top denied connection and which is causing high cpu and memory ..
would like to know if there any way to stop these sessions ..
Regards ..
Manik Palekar
Please enable "inspect icmp" and "inspect icmp error" and see if it helps.
If you have icmp inspection the FW will create conns per icmp pakcet that is see. Though if the response is coming from the wrong interface you will the "no connection" messages.
I would also suggest capturing the icmp packets on the FW interfaces if the icmp error persist.
PK
