Email alerts for RTMT
Sep 27th, 2010
We are getting alerts from RTMT that a Gateway has increased or decreased, but it doesnt state which one. Is there a way to get the alerts on which gateway is going down?
afmmanicke Mon, 09/27/2010 - 11:53
I had the same issue with not enough information out of the gate.   I just created a custom alert.   I went to Performance then selected the server the gateway was register to and navigated to Cisco MGCP Gateways -> PRISpansInService.   After you get the graph up you can create your own custom alert with custom text that has better speciffics.
Obviously this could be a little different if you're running SIP or H323 and not a PRI.
Related Content
