Get ‘500 Internal Server Error’ during SIP INVITE - cause 44
Sep 27th, 2010
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:"Times New Roman"; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi;}
Have you ever seen anything like this before?  It usually works, but intermittently, we see calls get rejected.  It somehow seems related to high loads on the router.  We reduced the occurrences by changing our code to throttle the number of SIP INVITEs we send, but this doesn’t scale well.  Once it occurs, the only way to clean it up is to do a shut/no shut on the voice-port associated to SIP INVITE.
Any suggestions on how we can proceed to debug this issue?
BACKGROUND:
Cisco 2811 running (C2800NM-ADVENTERPRISEK9-M), Version 12.4(24)T3, RELEASE SOFTWARE (fc2)
NAME: "2811 chassis", DESCR: "2811 chassis" PID: CISCO2811
NAME: "9 Port FE Switch on Slot 0 SubSlot 1", DESCR: "9 Port FE Switch" PID: HWIC-D-9ESW
NAME: "WIC/VIC/HWIC 1 Power Daughter Card", DESCR: "9-Port HWIC-ESW Power Daughter Card" PID: ILPM-8
NAME: "Two port E1 voice interface daughtercard on Slot 0 SubSlot 2", DESCR: "Two port E1 voice interface daughtercard" PID: VWIC-2MFT-E1=
NAME: "Two port E1 voice interface daughtercard on Slot 0 SubSlot 3", DESCR: "Two port E1 voice interface daughtercard" PID: VWIC-2MFT-E1=
NAME: "PVDMII DSP SIMM with four DSPs on Slot 0 SubSlot 4", DESCR: "PVDMII DSP SIMM with four DSPs" PID: PVDM2-64
NAME: "High Density Voice2 Network module with on board two port interface  on Slot 1", DESCR: "High Density Voice2 Network module with on board two port interface " PID: NM-HDV2-2T1/E1
NAME: "2nd generation two port EM voice interface daughtercard on Slot 1 SubSlot 0", DESCR: "2nd generation two port EM voice interface daughtercard" PID: VIC2-2E/M
NAME: "PVDMII DSP SIMM with four DSPs on Slot 1 SubSlot 2", DESCR: "PVDMII DSP SIMM with four DSPs" PID: PVDM2-64
NAME: "PVDMII DSP SIMM with four DSPs on Slot 1 SubSlot 3", DESCR: "PVDMII DSP SIMM with four DSPs" PID: PVDM2-64
NAME: "PVDMII DSP SIMM with four DSPs on Slot 1 SubSlot 4", DESCR: "PVDMII DSP SIMM with four DSPs" PID: PVDM2-64
NAME: "PVDMII DSP SIMM with four DSPs on Slot 1 SubSlot 5", DESCR: "PVDMII DSP SIMM with four DSPs" PID: PVDM2-64
WIRESHARK:
No.     Time        Source                Destination           Protocol Info
      2 0.057246    10.194.154.136        171.68.115.156        SIP      Status: 100 Trying
Frame 2 (471 bytes on wire, 471 bytes captured)
Ethernet II, Src: Cisco_0d:3c:c0 (00:1f:ca:0d:3c:c0), Dst: HewlettP_06:71:52 (00:1f:29:06:71:52)
Internet Protocol, Src: 10.194.154.136 (10.194.154.136), Dst: 171.68.115.156 (171.68.115.156)
User Datagram Protocol, Src Port: sip (5060), Dst Port: sip (5060)
Session Initiation Protocol
    Status-Line: SIP/2.0 100 Trying
    Message Header
        Via: SIP/2.0/UDP 171.68.115.156:5060;rport;branch=z9hG4bK-41a-100875-517454db
        From: <sip:[email protected]:5060>;tag=82f4a00-9c7344ab-13c4-45026-41a-4ea64c5a-41a
        To: <sip:[email protected]:5060>
        Date: Wed, 08 Sep 2010 20:47:49 GMT
        Call-ID: 80e4f50-9c7344ab-13c4-45026-41a-10aff3f4-41a
        CSeq: 1 INVITE
            Sequence Number: 1
            Method: INVITE
        Allow-Events: telephone-event
        Server: Cisco-SIPGateway/IOS-12.x
        Content-Length: 0
      3 0.071428    10.194.154.136        171.68.115.156        SIP/SDP  Status: 183 Session Progress, with session description
Frame 3 (1109 bytes on wire, 1109 bytes captured)
    Status-Line: SIP/2.0 183 Session Progress
   Message Header
        To: <sip:[email protected]:5060>;tag=48645D8-1175
        CSeq: 1 INVITE
            Sequence Number: 1
            Method: INVITE
        Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
        Remote-Party-ID: <sip:[email protected]>;party=called;screen=no;privacy=off
            [Expert Info (Note/Undecoded): Unrecognised SIP header (Remote-Party-ID)]
                [Message: Unrecognised SIP header (Remote-Party-ID)]
                [Severity level: Note]
                [Group: Undecoded]
        Contact: <sip:[email protected]:5060>
        Supported: sdp-anat
        Content-Type: application/sdp
        Content-Disposition: session;handling=required
        Content-Length: 264
    Message Body
        Session Description Protocol
            Session Description Protocol Version (v): 0
            Owner/Creator, Session Id (o): CiscoSystemsSIP-GW-UserAgent 8759 6996 IN IP4 10.194.154.136
                Owner Username: CiscoSystemsSIP-GW-UserAgent
                Session ID: 8759
                Session Version: 6996
                Owner Network Type: IN
                Owner Address Type: IP4
                Owner Address: 10.194.154.136
            Session Name (s): SIP Call
            Connection Information (c): IN IP4 10.194.154.136
                Connection Network Type: IN
                Connection Address Type: IP4
                Connection Address: 10.194.154.136
            Time Description, active time (t): 0 0
                Session Start Time: 0
                Session Stop Time: 0
            Media Description, name and address (m): audio 18710 RTP/AVP 18 101
                Media Type: audio
                Media Port: 18710
                Media Protocol: RTP/AVP
                Media Format: ITU-T G.729
                Media Format: DynamicRTP-Type-101
            Media Attribute (a): rtpmap:18 G729/8000
                Media Attribute Fieldname: rtpmap
                Media Format: 18
                MIME Type: G729
                Sample Rate: 8000
            Media Attribute (a): fmtp:18 annexb=no
                Media Attribute Fieldname: fmtp
                Media Format: 18 [G729]
                Media format specific parameters: annexb=no
            Media Attribute (a): rtpmap:101 telephone-event/8000
                Media Format: 101
               MIME Type: telephone-event
                Sample Rate: 8000
            Media Attribute (a): fmtp:101 0-16
                Media Format: 101 [telephone-event]
                Media format specific parameters: 0-16
      4 0.089917    10.194.154.136        171.68.115.156        SIP/SDP  Status: 200 OK, with session description
Frame 4 (1116 bytes on wire, 1116 bytes captured)
    Status-Line: SIP/2.0 200 OK
    Message Header
        CSeq: 1 INVITE
            Sequence Number: 1
            Method: INVITE
                [Group: Undecoded]
        Supported: replaces
        Supported: sdp-anat
        Content-Length: 264
    Message Body
                Session ID: 8759
                Media Type: audio
                Media Port: 18710
                Media Format: 18
                MIME Type: G729
                Sample Rate: 8000
                Media Format: 101
                Sample Rate: 8000
     7 1.661867    10.194.154.136        171.68.115.156        SIP      Status: 100 Trying
Frame 7 (469 bytes on wire, 469 bytes captured)
    Message Header
        Via: SIP/2.0/UDP 171.68.115.156:5060;rport;branch=z9hG4bK-41c-100eca-13593e22
        From: <sip:[email protected]:5060>;tag=82f4b98-9c7344ab-13c4-45026-41c-669825d-41c
        Date: Wed, 08 Sep 2010 20:47:51 GMT
        Call-ID: 80e5138-9c7344ab-13c4-45026-41c-3f6bfc7-41c
        CSeq: 1 INVITE
            Sequence Number: 1
            Method: INVITE
        Content-Length: 0
      8 1.676056    10.194.154.136        171.68.115.156        SIP/SDP  Status: 183 Session Progress, with session description
Frame 8 (1107 bytes on wire, 1107 bytes captured)
    Message Header
        To: <sip:[email protected]:5060>;tag=4864C1C-10F8
        CSeq: 1 INVITE
            Sequence Number: 1
            Method: INVITE
                [Group: Undecoded]
        Supported: sdp-anat
        Content-Length: 264
    Message Body
            Owner/Creator, Session Id (o): CiscoSystemsSIP-GW-UserAgent 7991 6854 IN IP4 10.194.154.136
                Session ID: 7991
                Session Version: 6854
            Media Description, name and address (m): audio 17660 RTP/AVP 18 101
                Media Type: audio
                Media Port: 17660
                Media Format: 18
                MIME Type: G729
                Sample Rate: 8000
                Media Format: 101
                Sample Rate: 8000
     10 1.700567    10.194.154.136        171.68.115.156        SIP      Status: 100 Trying
Frame 10 (471 bytes on wire, 471 bytes captured)
    Message Header
        Via: SIP/2.0/UDP 171.68.115.156:5060;rport;branch=z9hG4bK-41c-100f04-2fde97a9
        From: <sip:[email protected]:5060>;tag=82f4d30-9c7344ab-13c4-45026-41c-5c20b753-41c
        Call-ID: 80e5320-9c7344ab-13c4-45026-41c-7fbe4865-41c
        CSeq: 1 INVITE
            Sequence Number: 1
            Method: INVITE
        Content-Length: 0
     11 1.726376    10.194.154.136        171.68.115.156        SIP/SDP  Status: 200 OK, with session description
Frame 11 (1114 bytes on wire, 1114 bytes captured)
    Message Header
        CSeq: 1 INVITE
            Sequence Number: 1
            Method: INVITE
                [Group: Undecoded]
        Supported: replaces
        Supported: sdp-anat
        Content-Length: 264
    Message Body
                Session ID: 7991
                Media Type: audio
                Media Port: 17660
                Media Format: 18
                MIME Type: G729
                Sample Rate: 8000
                Media Format: 101
                Sample Rate: 8000
     13 1.727645    10.194.154.136        171.68.115.156        SIP      Status: 500 Internal Server Error
Frame 13 (526 bytes on wire, 526 bytes captured)
    Status-Line: SIP/2.0 500 Internal Server Error
    Message Header
        To: <sip:[email protected]:5060>;tag=4864C50-3C3
        CSeq: 1 INVITE
            Sequence Number: 1
            Method: INVITE
        Reason: Q.850;cause=44
            Reason Protocols: Q.850
            Cause: 44(0x2c)[Requested circuit/channel not available]
        Content-Length: 0
Thanks!
-John
Paolo Bevilacqua Tue, 09/28/2010 - 04:19
Since it appears you are a Cisco Employee, my recommendation is that you use the many internal resource available to you (including, but not limited to) , like TAC access, internal forums, team leaders, etc.
This not to give the casual reader, the impression that the best source of support at Cisco is a customer's public forum.
