loop in a DMP-4305
Answered Question
Sep 27th, 2010
Hi  friends.
I´m working with a dmp-4305 i make a HTML file using the base of Tomas de leon but i can only see a white screen, see my doc.
<html>
<head>
<meta http--equiv="content-type" content="text/html; charset=ISO-8859-1">
<title>..:: Playlist (local storage) ::.. </title>
<style>
body {
margin: 0px;
background--color: #FF6600;
#movie {
width: 1366px;
height: 768px;
border--width: px;
border--style: ridge;
border--color: #efb525;
</style>
<script language="JavaScript" src="file:///tivella/tvzilla/js/tivella.js"></script>
<script language="JavaScript">
var mediaPlayer; // MediaPlayer object.
var position = new Object(); // Current movie position.
var duration = new Object(); // Movie duration.
var active = new Object(); // Playing is in progress.
var movieTimeout = 3000; // Movie checking interval in milliseconds.
var i = 0;
var timer = 0;
const STATUS_IDLE = 0;
const STATUS_PLAYING = 1;
const TRIES_LIMIT = 10;
var status = STATUS_IDLE;
var tries = 0;
// Put your movie URLs here.
var playlist = new Array(
file:///tmp/ftproot/usb_1/dmp/001.mpg
function init()
var el = document.getElementById("movie");
mediaPlayer = new tvMediaPlayer();
//Make white non-transparent background
mediaPlayer.osdSetAlpha(window, 0, 0, window.screen.width, window.screen.height, 255);
if (el)
mediaPlayer.setOutputElement(window, el, 0);
// Set the left and right volume levels
mediaPlayer.setRightVolume(10);
mediaPlayer.setLeftVolume(10);
movie() ;
function destroy()
mediaPlayer.stop() ;
mediaPlayer.setFullScreen();
function nextItem()
mediaPlayer.play(playlist[i]) ;
status = STATUS_PLAYING;
++i;
if (i >= playlist.length)
i = 0;
tries = 0;
function movie()
switch (status) {
case STATUS_IDLE:
nextItem();
break;
case STATUS_PLAYING:
//Position would now be in position.value
mediaPlayer.getPosition(position);
//Duration would now be in duration.value
mediaPlayer.getDuration(duration);
if ((duration.value > 0 && position.value > 0 && position.value == duration.value) ||
(duration.value == 0 && position.value == 0 && ++tries > TRIES_LIMIT)) {
nextItem();
break;
if (timer)
window.clearTimeout(timer);
timer = window.setTimeout("movie();", movieTimeout);
</script>
</head><body onload="init();" onunload="destroy();">
<div id="movie"></div>
</body>
</html>
This is the link that i put in the browser section file:///tmp/ftproot/usb_1/loop.html
It´s my firts DMP project and i dont´s have a DMM i would like play a video loop, another question where i have to paste de Index.HTML?? in the USB_1 carpet usin the Filezilla or not??
Thank for your help.
Correct Answer by Tomas De Leon about 6 years 8 months ago
Carlos,
I just tested the file attached on my DMP and
it works fine.
* You need to edit the file for your content and where it is stored
  on the DMP.
I created the following directories using an FTP client:
/usb1/html
/usb1/movies
/usb1/music
/usb1/videos
* I copied the local-mpg-file.html file into the ../html directory and then copied my
  content (Cisco-HN-DoctorVisit.mpg) into the ../videos directory
* I then added the following URL:
  file:///tmp/ftproot/usb_1/html/local-mpg-file.html
   in the "Startup URLs" section for the "Browser" field value.
* Saved DMP configuration
* Restarted DMP
Note:  I performed these task using the DMP-DM Web Admin and a FTP client.
The DMP restarted and played the local video repeatedly in a loop.
If this answers your question, Please take time to mark this
discussion answered & rate the response.
Thank You!
T.
Overall Rating: 5 (1 ratings)
Correct Answer
Tomas De Leon Tue, 09/28/2010 - 11:21
  • Cisco Employee,
Carlos,
it works fine.
  on the DMP.
/usb1/html
/usb1/movies
/usb1/music
/usb1/videos
* Restarted DMP
Thank You!
T.
carlosmc631 Mon, 10/04/2010 - 20:30
It´s works it´s works!!!!!!!!!!!!!!!!!!! Thanks a lot Tomas now is playing the loop and i can change the video.
Thanks again and well it´s my first DMP installation.
