Cisco 3945 with SFP - full duplex possible?
Sep 27th, 2010
My provider (Deutsche Telekom) is only able to hand over a 1Gbps-Link with speed und full-duplex configured fix.
To force the router (cisco 3945) for 1000/full, I had to remove the 'media-type sfp'
SFP is MM-SX on Router-Interface Gi0/2
This configuration worked a while but shows many interface resets (more than 30 in one minute).
Telekom confirmed, their connection is working properly.
After switching the router off an on, I could no longer connect with telnet or ssh. Ping is also not successful but cdp shows the neighbor router!?!
Maybe this is a problem with SFP and duplex configuration.
Any ideas?
Overall Rating: 5 (1 ratings)
Jean-Pierre Burlet Tue, 09/28/2010 - 04:24
with Gigabit there is only full. But it could also be the software. A customer of us has had almost the same problems and by a software update the problem was repaired.
adjovikoffi Fri, 02/26/2016 - 01:28
my problem is that my cisco router 3845-MB has its interface gig0/0 down. admistratively down. the ios version is the 12.4(20)T4 ,do i upgrade the version? if yes which one doesnt have a such bug.
thanks to reply
mbrunton77 Tue, 09/28/2010 - 07:48
have you tried the command speed nonegotiate under the interface?
kluehspiesp Wed, 09/29/2010 - 08:05
After replacing the 3945 with a 3845 the Link is up and running - without any 'interface resets'
dahirton Thu, 11/25/2010 - 12:47
Hi, I'm facing a similar issue with a 3845 with GLC-SX-MM module trying to connect at 100Mbps with a telco device. Documentations says 'media-type sfp' defaults to 1Gig, and only changing to 'media-type rj45' would allow me to set 100Mbps instead. Any clue what should I do in order to allow speed compatibility with this telco device ? Follows the current interface config:
Interface GigabitEthernet0/0
description ---
bandwidth 100000
no ip address
duplex auto
speed 1000
media-type sfp
negotiation auto
kluehspiesp Thu, 11/25/2010 - 23:35
with IOS version 15.0(1)M4 the Gig interface can be left on speed/duplex autosensing mode. Its default is to connect with 1000/full, again.
IOS versions before connected with half-duplex.
The new software fixed the Bug CSCtj35792
Tom Randstrom Fri, 11/26/2010 - 07:48
In order to connect to a 100BaseFX link, you will need to install a GLC-GE-100FX SFP module in your 3945 switch.  This 100M SFP module is designed to be installed in a GE SFP slot.
If, in the future, you want to support GE on the 3945 switch's port, you will have to change the SFP to a compatible GE module.
Hope this helps!
Tom
kluehspiesp Tue, 11/30/2010 - 02:45
the request was to connect a 1000/full link.
After the software update it works without any problems
tarunvyas Sat, 09/24/2011 - 03:41
Did Router 3945 SFP Port support SFP-10G-LR, How to define it ?
loizosko Tue, 08/13/2013 - 20:00
i had the same problem. 3925 running 151-3T. we got a new isp link that required glc-sx-mm. the link was not coming up.
i tried different gbics.
no command to nonegotiate or specify speed/duplex
i upgraded ios to 153.2T and interface came right up.
still don't have those commands but it works.
there must be a bug or something in some of the ios.
