UCCE - Agent restrictions
Sep 28th, 2010
Does anyone know if the same agent restrictions that apply to UCCX apply to UCCE.
I can't find anything in the release notes to verify this.
From UCCX release notes:-
The following configurations are not supported for agent phones:
•Two lines on an agent’s phone that have the same extension but exist in different partitions.
•A Unified CCX extension assigned to multiple devices.
•Configuring the same Unified CCX extension in more than one device profile, or configuring the same Unified CCX extension in any combination of device profiles and devices. (Configuring an Unified CCX extension in a single device profile is supported.)
•In the Unified CM Administration Directory Number Configuration web page for each Unified CCX line, setting Maximum Number of Calls to a value other than 2.
•In the Unified CM Administration Directory Number Configuration web page for each Unified CCX line, setting Busy Trigger to a value other than 1.
•Configuring a Cisco Unified IP Phone with Secure Real-Time Protocol (SRTP) for use in silent monitoring and recording.
•No Cisco Unified Communications Manager device can be forwarded to the Unified CCX extension of an agent.
From this they have to be in their own partition along with the other CCE resources and gateways.
david.macias Tue, 09/28/2010 - 06:05
  • Blue, 1500 points or more
As a rule of thumb anything in the 7.x branch and earlier yes, the 8.x branch has a little more flexibility, but not that much.
david
Related Content
