Kostas Kyriakos Tue, 09/28/2010 - 02:48
Hello.
Please try the following for starters:
! Define a ReadOnly Community
snmp-server community RO
! Define an IP Interface, sourcing the traps. Make sure you verify ip connectivity to the NMS Server, from this interface.
snmp-server trap-source
! Define the NMS Server IP
snmp-server host
! Try this sample trap configuration
snmp-server enable traps snmp authentication linkdown linkup coldstart warmstart
You can define additional traps with the command:
snmp-server enable traps ?
Hope this helps.
sam-lee Tue, 09/28/2010 - 03:24
How about syslog? What needs to be configured
for authnetication failure or link down to be send via syslog? What's the cmd? Thanks!!
jonathanaxford Tue, 09/28/2010 - 03:26
Syslog can be configured by using the following
logging x.x.x.x
You can set the logging level of the traps that get sent ot the NMS using the:
logging trap [level] command.
Hope this helps,
Jonathan
