IPCCx License Real Time Counter/Log?
Sep 28th, 2010
Does anyone know if there is a way to see how many IPCCx enhanced licenses out of the pool are being used at any one time? Can it be reported on?
Cheers,
Rich
Aaron Harrison Wed, 09/29/2010 - 01:20
  • Community Spotlight Award,
    Member's Choice, May 2015
Version 8 - no idea
Pre Version 8 - you can run 'showlicenseusage.exe' from the cmd window on the server (it's in program files\cisco\desktop\bin) to see how many seats are in use and by whom.
It's not logged to the DB unfortunately, so no reporting as such.
Aaron
Please rate helpful posts..
ritsonr Wed, 09/29/2010 - 02:06
Hmmmm, i'm running IPCC Express Enhanced version 4.0(5)SR02 and in program files/cisco/desktop/bin there isnt an exe called show license files.... Have looked in the directory and run int from cmd...
Am i doing something wrong?
Aaron Harrison Wed, 09/29/2010 - 02:21
I've just logged on to my 4.x lab and it isn't there either - it must have been introduced in version 5.0
Aaron
Pablo Leiva Wed, 09/29/2010 - 05:35
  • Silver, 250 points or more
The showlicenseusage utility is available for 5.x and higher. The closest thing in 4.0(5) to determine the current usage is to use the Real Time Reporting to see how many agents are logged in.
Pablo
Related Content
