IPSec vpn to asa 5510
Answered Question
Sep 28th, 2010
Hi all
For a couple off days now, I am trying to resolve the fol lowong
issue, I am not really expierenced in ASA's or vpn, so any help will be appreciated.
I'm trying so set up an remote access vpn to an asa. but
I get he following error:
firewall# Sep 28 04:04:40 [IKEv1]: Group = RECOR, Username = pptpusr01, IP = xxxxxxxxxxxx
, QM FSM error (P2 struct &0xac69d548, mess id 0x14921bd8)!
Sep 28 04:04:40 [IKEv1]: Group = RECOR, Username = pptpusr01, IP =xxxxxxxxxxxxxxxxxxxxx
, Removing peer from correlator table failed, no match!
I have attached my running config
If anyone has an idea, pleasen let me know.
Kind regards
Bert
Correct Answer by Jennifer Halim about 6 years 3 months ago
Assuming that you are not using L2TP, please kindly remove the following line:
crypto dynamic-map outside_dyn_map 20 set transform-set recor_l2tp
Overall Rating: 5 (1 ratings)
Jennifer Halim Tue, 09/28/2010 - 05:42
The following configuration should be removed as it is not required:
no access-list inside_nat0_outbound_1 extended permit ip 192.0.0.0 255.255.255.0 object-group DM_INLINE_NETWORK_1
no access-list inside_nat0_outbound_1 extended permit ip any 192.0.0.128 255.255.255.224
no nat (inside) 0 access-list inside_nat0_outbound_2 outside
no access-list inside_nat0_outbound_2 extended permit ip object-group VPNSites 172.16.0.0 255.255.255.0
After the above changes, please run the following debugs on ASA:
debug cry isa
debug cry ipsec
Please also turn on logs on VPN Client.
Collect the debug output from ASA and logs from VPN Client after trying to connect via vpn client.
Bert Kelchtermans Wed, 09/29/2010 - 00:16
Thanks for the help
But are you sure that I should remove those access-lists, because we also have some site-to-site-vpn connections.
Here is the output I got from
debug cry ipsec
debug cry isa
Sep 29 00:01:37 [IKEv1]: Group = TUNNELRECOR, Username = pptpusr01, IP
= XXXXXXXXXXXXXXX, QM FSM error (P2 struct &0xae63f758, mess id 0xea4f7e96)!
Sep 29 00:01:37 [IKEv1]: Group = TUNNELRECOR, Username = pptpusr01, IP = XXXXXXXXXX
This is the log from my ipsec client.
Cisco Systems VPN Client Version 5.0.03.0560
Copyright (C) 1998-2007 Cisco Systems, Inc. All Rights Reserved.
Client Type(s): Windows, WinNT
Running on: 5.1.2600 Service Pack 3
Config file directory: C:\Program Files\Cisco Systems\VPN Client\
1      09:10:17.483  09/29/10  Sev=Info/4    CM/0x63100002
Begin connection process
2      09:10:17.498  09/29/10  Sev=Info/4    CM/0x63100004
Establish secure connection
3      09:10:17.498  09/29/10  Sev=Info/4    CM/0x63100024
Attempt connection with server "94.107.244.10"
4      09:10:17.514  09/29/10  Sev=Info/6    IKE/0x6300003B
Attempting to establish a connection with 94.107.244.10.
5      09:10:17.530  09/29/10  Sev=Info/4    IKE/0x63000013
SENDING >>> ISAKMP OAK AG (SA, KE, NON, ID, VID(Xauth), VID(dpd), VID(Frag), VID(Nat-T), VID(Unity)) to 94.107.244.10
6      09:10:17.530  09/29/10  Sev=Info/5    IKE/0x6300002F
Received ISAKMP packet: peer = 94.107.244.10
7      09:10:17.530  09/29/10  Sev=Info/4    IKE/0x63000014
RECEIVING <<< ISAKMP OAK AG (SA, KE, NON, ID, HASH, VID(Unity), VID(Xauth), VID(dpd), VID(Frag), VID(?)) from 94.107.244.10
8      09:10:17.530  09/29/10  Sev=Info/5    IKE/0x63000001
Peer is a Cisco-Unity compliant peer
9      09:10:17.530  09/29/10  Sev=Info/5    IKE/0x63000001
Peer supports XAUTH
10     09:10:17.530  09/29/10  Sev=Info/5    IKE/0x63000001
Peer supports DPD
11     09:10:17.530  09/29/10  Sev=Info/5    IKE/0x63000001
Peer supports IKE fragmentation payloads
12     09:10:17.545  09/29/10  Sev=Info/6    IKE/0x63000001
IOS Vendor ID Contruction successful
13     09:10:17.545  09/29/10  Sev=Info/4    IKE/0x63000013
SENDING >>> ISAKMP OAK AG *(HASH, NOTIFY:STATUS_INITIAL_CONTACT, VID(?), VID(Unity)) to 94.107.244.10
14     09:10:17.545  09/29/10  Sev=Info/4    IKE/0x63000083
IKE Port in use - Local Port =  0x066D, Remote Port = 0x01F4
15     09:10:17.545  09/29/10  Sev=Info/4    CM/0x6310000E
Established Phase 1 SA.  1 Crypto Active IKE SA, 0 User Authenticated IKE SA in the system
16     09:10:17.545  09/29/10  Sev=Info/5    IKE/0x6300002F
Received ISAKMP packet: peer = XXXXXXXXXXXXXXXXXXXXXXXXX
17     09:10:17.545  09/29/10  Sev=Info/4    IKE/0x63000014
RECEIVING <<< ISAKMP OAK TRANS *(HASH, ATTR) from XXXXXXXXXXXXXXXXXXXXXXXXX
18     09:10:17.545  09/29/10  Sev=Info/4    CM/0x63100015
Launch xAuth application
19     09:10:17.623  09/29/10  Sev=Info/4    IPSEC/0x63700008
IPSec driver successfully started
20     09:10:17.623  09/29/10  Sev=Info/4    IPSEC/0x63700014
Deleted all keys
21     09:10:23.030  09/29/10  Sev=Info/4    CM/0x63100017
xAuth application returned
22     09:10:23.030  09/29/10  Sev=Info/4    IKE/0x63000013
SENDING >>> ISAKMP OAK TRANS *(HASH, ATTR) to 94.107.244.10
23     09:10:23.030  09/29/10  Sev=Info/5    IKE/0x6300002F
24     09:10:23.030  09/29/10  Sev=Info/4    IKE/0x63000014
25     09:10:23.030  09/29/10  Sev=Info/4    IKE/0x63000013
SENDING >>> ISAKMP OAK TRANS *(HASH, ATTR) to XXXXXXXXXXXXXXXXXXXXXXXXX
26     09:10:23.030  09/29/10  Sev=Info/4    CM/0x6310000E
Established Phase 1 SA.  1 Crypto Active IKE SA, 1 User Authenticated IKE SA in the system
27     09:10:23.623  09/29/10  Sev=Info/5    IKE/0x6300005E
Client sending a firewall request to concentrator
28     09:10:23.623  09/29/10  Sev=Info/5    IKE/0x6300005D
Firewall Policy: Product=Cisco Systems Integrated Client Firewall, Capability= (Centralized Protection Policy).
29     09:10:23.639  09/29/10  Sev=Info/4    IKE/0x63000013
30     09:10:23.639  09/29/10  Sev=Info/5    IKE/0x6300002F
31     09:10:23.639  09/29/10  Sev=Info/4    IKE/0x63000014
32     09:10:23.639  09/29/10  Sev=Info/5    IKE/0x63000010
MODE_CFG_REPLY: Attribute = INTERNAL_IPV4_ADDRESS: , value = 192.0.0.141
33     09:10:23.639  09/29/10  Sev=Info/5    IKE/0x63000010
MODE_CFG_REPLY: Attribute = INTERNAL_IPV4_NETMASK: , value = 255.255.255.0
34     09:10:23.639  09/29/10  Sev=Info/5    IKE/0x63000010
MODE_CFG_REPLY: Attribute = INTERNAL_IPV4_DNS(1): , value = 192.0.0.29
35     09:10:23.639  09/29/10  Sev=Info/5    IKE/0x63000010
MODE_CFG_REPLY: Attribute = INTERNAL_IPV4_DNS(2): , value = 192.0.0.30
36     09:10:23.639  09/29/10  Sev=Info/5    IKE/0x6300000D
MODE_CFG_REPLY: Attribute = MODECFG_UNITY_SAVEPWD: , value = 0x00000000
37     09:10:23.639  09/29/10  Sev=Info/5    IKE/0x6300000E
MODE_CFG_REPLY: Attribute = MODECFG_UNITY_DEFDOMAIN: , value = XXXXXXXXXXXXXXXXXXXXXXXXX
38     09:10:23.639  09/29/10  Sev=Info/5    IKE/0x6300000D
MODE_CFG_REPLY: Attribute = MODECFG_UNITY_PFS: , value = 0x00000000
39     09:10:23.639  09/29/10  Sev=Info/5    IKE/0x6300000E
MODE_CFG_REPLY: Attribute = APPLICATION_VERSION, value = Cisco Systems, Inc ASA5510 Version 8.2(1) built by builders on Tue 05-May-09 22:45
40     09:10:23.639  09/29/10  Sev=Info/5    IKE/0x6300000D
MODE_CFG_REPLY: Attribute = MODECFG_UNITY_SMARTCARD_REMOVAL_DISCONNECT: , value = 0x00000001
41     09:10:23.639  09/29/10  Sev=Info/4    CM/0x63100019
Mode Config data received
42     09:10:23.655  09/29/10  Sev=Info/4    IKE/0x63000056
Received a key request from Driver: Local IP = 192.0.0.141, GW IP = XXXXXXXXXXXXXXXXXXXXXXXXX, Remote IP = 0.0.0.0
43     09:10:23.655  09/29/10  Sev=Info/4    IKE/0x63000013
SENDING >>> ISAKMP OAK QM *(HASH, SA, NON, ID, ID) to 94.107.244.10
44     09:10:23.670  09/29/10  Sev=Info/5    IKE/0x6300002F
45     09:10:23.670  09/29/10  Sev=Info/4    IKE/0x63000014
RECEIVING <<< ISAKMP OAK INFO *(HASH, NOTIFY:STATUS_RESP_LIFETIME) from 94.107.244.10
46     09:10:23.670  09/29/10  Sev=Info/5    IKE/0x63000045
RESPONDER-LIFETIME notify has value of 86400 seconds
47     09:10:23.670  09/29/10  Sev=Info/5    IKE/0x63000047
This SA has already been alive for 6 seconds, setting expiry to 86394 seconds from now
48     09:10:23.670  09/29/10  Sev=Info/5    IKE/0x6300002F
49     09:10:23.670  09/29/10  Sev=Info/4    IKE/0x63000014
RECEIVING <<< ISAKMP OAK INFO *(HASH, NOTIFY:NO_PROPOSAL_CHOSEN) from 94.107.244.10
50     09:10:23.670  09/29/10  Sev=Info/4    IKE/0x63000013
SENDING >>> ISAKMP OAK INFO *(HASH, DEL) to 94.107.244.10
51     09:10:23.670  09/29/10  Sev=Info/4    IKE/0x63000049
Discarding IPsec SA negotiation, MsgID=EA4F7E96
52     09:10:23.670  09/29/10  Sev=Info/4    IKE/0x63000017
Marking IKE SA for deletion  (I_Cookie=9D3BF51BDE44D6A5 R_Cookie=4FC9E37E218D5CEA) reason = DEL_REASON_IKE_NEG_FAILED
53     09:10:23.670  09/29/10  Sev=Info/5    IKE/0x6300002F
Received ISAKMP packet: peer =XXXXXXXXXXXXXXXXXXXXXXXXX
54     09:10:23.670  09/29/10  Sev=Info/4    IKE/0x63000058
Received an ISAKMP message for a non-active SA, I_Cookie=9D3BF51BDE44D6A5 R_Cookie=4FC9E37E218D5CEA
55     09:10:23.670  09/29/10  Sev=Info/4    IKE/0x63000014
RECEIVING <<< ISAKMP OAK INFO *(Dropped) from 94.107.244.10
56     09:10:24.623  09/29/10  Sev=Info/4    IPSEC/0x63700014
Deleted all keys
57     09:10:27.123  09/29/10  Sev=Info/4    IKE/0x6300004B
Discarding IKE SA negotiation (I_Cookie=9D3BF51BDE44D6A5 R_Cookie=4FC9E37E218D5CEA) reason = DEL_REASON_IKE_NEG_FAILED
58     09:10:27.123  09/29/10  Sev=Info/4    CM/0x63100012
Phase 1 SA deleted before first Phase 2 SA is up cause by "DEL_REASON_IKE_NEG_FAILED".  0 Crypto Active IKE SA, 0 User Authenticated IKE SA in the system
59     09:10:27.123  09/29/10  Sev=Info/5    CM/0x63100025
Initializing CVPNDrv
60     09:10:27.139  09/29/10  Sev=Info/6    CM/0x63100046
Set tunnel established flag in registry to 0.
61     09:10:27.139  09/29/10  Sev=Info/4    IKE/0x63000001
IKE received signal to terminate VPN connection
62     09:10:27.139  09/29/10  Sev=Info/4    IPSEC/0x63700014
Deleted all keys
63     09:10:27.139  09/29/10  Sev=Info/4    IPSEC/0x63700014
Deleted all keys
64     09:10:27.139  09/29/10  Sev=Info/4    IPSEC/0x63700014
Deleted all keys
65     09:10:27.139  09/29/10  Sev=Info/4    IPSEC/0x6370000A
IPSec driver successfully stopped
Thanks in advance
Bert
Jennifer Halim Wed, 09/29/2010 - 05:28
Yes, you should remove that because it is already covered under the following NAT:
nat (inside) 0 access-list inside_nat0_outbound_1
You currently have 2 NAT exemption statements on inside interface, and the one with "outside" keyword should be removed.
And also add the following as from the debugs IPSec proposal does not match:
crypto dynamic-map remote-dyn-map 20 set transform-set ESP-3DES-MD5
crypto dynamic-map remote-dyn-map 50 set transform-set ESP-3DES-SHA
crypto map outside_map 65000 ipsec-isakmp dynamic remote-dyn-map
Bert Kelchtermans Thu, 09/30/2010 - 00:13
Hi Jennifer
Thank you for all the help, I've added the commands you gave me but
I am still getting the same error messagesfrom the debugs,
When I use my vpn client to connect, i have to login with my usernme and password
and the i get "securing communications channel"  followed by "not connected"
I've attachted them.
Thank you
Bert
Correct Answer
Jennifer Halim Thu, 09/30/2010 - 00:41
Bert Kelchtermans Thu, 09/30/2010 - 03:00
That solved my problem, thank very much.
I have one more question.
My network looks like this
ASA5510 ---------------------------Router (don't know the type, not managed by me)-----------------------Internal network
Will the people who connect to the vpn have local lan access?
I can't test this until saturday, I was just wondering because they told me that that was an issue with previous installations.
Again, thank very much
Jennifer Halim Thu, 09/30/2010 - 03:56
Base on your configuration, your ip local pool for the vpn is in the same subnet as your internal network. You should change the pool to a different unique subnet.
Then you would need to add the "inside_nat0_outbound" with the newly created ip pool subnet:
access-list inside_nat0_outbound extended permit ip any
Assuming that the router that is not managed by you has default gateway pointing towards the ASA inside interface, you should have access to your internal network. That is the purpose of IPSec VPN client, ie: to get access to your internal network.
Bert Kelchtermans Thu, 09/30/2010 - 04:20
So if i understand correctly, i should change the following:
ip local pool VPN-Clients 192.0.1.2-192.0.1.150 mask 255.255.255.0
access-list inside_nat0_outbound extended permit ip any <192.0.1.0> <255.255.255.0>
What about the dns server setting,  it is now on 192.0.0.29, does this have to change.
I have adjusted my topology, the previous one, was not correct. The internal network is directly connected to the asa.
ASA5510(192.0.0.40) ---------------------------(192.0.0.187)Router (don't know the type, not managed by me)
                                |----------------------Internal network (192.0.0.0)
thank you
Jennifer Halim Thu, 09/30/2010 - 04:33
Yes, absolutely correct.
DNS can stay the same if that is the correct internal dns server ip address.
Bert Kelchtermans Thu, 09/30/2010 - 04:55
Ok, thank you very much
EDIT: I have configured my asa like you suggested, but i still don't seem to have Local Lan Access.
These are the settings i get from my dhcp pool
Connection-specific DNS Suffix  . : xxxxxxxxxxxxxxxxx
IP Address. . . . . . . . . . . . : 192.0.1.2
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . : 192.0.1.2
One last question, i have to forward a couple of ports to the router
Is this the correct?
access-list outside-access-in extended permit tcp any interface outside eq 3389
static (inside,outside) tcp interface 3389 192.0.0.187 3389 netmask 255.255.255.255
thank you
Jennifer Halim Thu, 09/30/2010 - 05:35
No, you don't have to forward anything on the ASA.
Once you VPN in, you should be able to access 192.0.0.187 if it's allowed for RDP. Please kindly make sure that personal firewall on that PC is turned off as it will not allow inbound connection from a different subnet.
Bert Kelchtermans Thu, 09/30/2010 - 05:44
Hello
Ok, but when i connect i still cannot ping other clients in the network or the inside interface of the asa.
And when connected, the default gateway points to my clients IP adres
Thank you
