NAC guest notification for Guest users
Sep 28th, 2010
Hi all,
did NAC guest send notification and report automatically if the guest user time is finished ,and how?
i will give 5 star
Overall Rating: 5 (1 ratings)
Serge Yasmine Wed, 10/06/2010 - 00:48
NGS acts as a Radius Server for the WLC to  authenticate the guest users. It doesn't notify when the guest user  lifetime is over, this is out of Scope of Radius Protocol.
Rather a session timeout radius attribute is sent from NGS to WLC upon  login of the guest user on the web auth SSID. This takes effect on the WLC and the user is removed from WLC when the timeout is over.
You need to have AAA Override enabled on the SSID.
From that link:
  1. Choose the the Advanced tab.
  2. Enable Allow AAA Override. This allows the per                 client session timeout to be set from the NAC Guest                 Appliance.
Trending Topics - Security & Network
