H.323 and MGCP gateway
Answered Question
Sep 28th, 2010
Dears,
Greetings , i asked if can deploy H.323 protocol and MGCP protocol in the same gateway using AS5350XM or AS5400XM Voice gateways and 1 TFTP server and 5 call managers 7.1 .
Regards.
Correct Answer by Paolo Bevilacqua about 6 years 4 months ago
AS5xxx does not have FXO.
MGCP is an inferior protocol, to be avoided whenever possible.
Overall Rating: 5 (1 ratings)
RAMI ABDALLAH K... Tue, 09/28/2010 - 06:26
Thanks Paolo , the customer request to deploye H.323 for PSTN  Line and MGCP for FXO "tellular" connection , i dont know order new VGateway or if it available to reduce tender cost  deploye both protocols in the same gateway .
thank you for your response
Correct Answer
Paolo Bevilacqua Tue, 09/28/2010 - 11:29
husali Wed, 09/29/2010 - 03:54
With MGCP you are relying on CUCM for call routing and control logic. H323 is all native to the GW.
