PIX firewall blocks VPN Clients
Answered Question
Sep 28th, 2010
Hello guys,
I have a PIX 501 firewall in my company's network. When customers from outside come inside the company and they trying to
connect to their sites via Cisco VPN client, the PIX 501 stops the VPN connection.
Any suggestions?
Thank you
Leon
Correct Answer by Jennifer Halim about 6 years 7 months ago
It depends on which version of PIX you are running.
This is assuming that the PIX firewall is passing through IPSec tunnel:
Here is a sample configuration for PIX version 6.x:
http://www.cisco.com/en/US/tech/tk583/tk372/technologies_configuration_example09186a008009486e.shtml
Here is sample configuration for PIX version 7.x and above:
http://www.cisco.com/en/US/products/ps6120/products_configuration_example09186a008045a2d2.shtml
Hope that helps.
Overall Rating: 5 (1 ratings)
Jennifer Halim Tue, 09/28/2010 - 06:39
  • Cisco Employee,
Do you mean the VPN connection pass through the PIX firewall? or terminate on the PIX firewall?
If it passes through the PIX firewall:
1) What version of PIX firewall do you have?
2) Are you configuring static NAT for the VPN traffic?
3) Have you configure ACL to allow the VPN traffic?
4) What VPN protocol are you using? IPSec? PPTP? L2TP over IPSec?
leonnikolaou Tue, 09/28/2010 - 07:01
Hi Jennifer,
The PIX is not configured for VPN, this is for sure. To be honest, I need to make a password recovery on that PIX cause I just came into this company
and they have lost the password of the PIX. I'm not really familiar with PIX firewalls so could you pls tell me any commands (natting, acls) that allows VPN
traffic to pass through the firewall?
Thank you
Leon
Correct Answer
Jennifer Halim Tue, 09/28/2010 - 07:07
  • Cisco Employee,
Hope that helps.
leonnikolaou Tue, 09/28/2010 - 07:17
These configuration will really help. The PIX Version is 6.3 (5)
Thanks a lot Jennifer.
