Can you do DMZ and NAT/PAT with a single public IP address on ASA5520?
Sep 28th, 2010
Can you do DMZ and NAT/PAT with a single public IP address on ASA5520? I have uplink in PPPoE and has only one public ip address. Would like to put anti-spam(eg. A.B.C.44) in the DMZ and there are a number of servers(eg. X.Y.Z.1, X.Y.Z.2 and X.Y.Z.3) that I want to NAT/PAT. Could someone please suggest how it should be implemented?
Two site-to-site IPSec tunnels have also been configured on this ASA.
Thanks to everyone in advance for your knowledge sharing.
Collin Clark Tue, 09/28/2010 - 12:17
You can do it. You need to configure what is called static NAT port translations.
For example lets say your public IP is
static (dmz,outside) tcp 25 A.B.C.44 25 netmask
! This static NAT port translation allows SMTP from the outside to your anti-spam server in the DMZ.
static (inside,outside) tcp 80 X.Y.Z.1 80 netmask
static (inside,outside) tcp 443 X.Y.Z.2 443 netmask
! Here we create a couple of static NAT port translations to allow HTTP to one server and HTTPS to another.
There is always a gotcha. You cannot reuse multiple ports in use. For example it is forbidden to have these two statements together.
static (inside,outside) tcp 80 X.Y.Z.2 80 netmask
! We are using port 80 on the outside and translating to two internal servers. This is not allowed. You can use one of them but not both.
There is a "work around". You can translate one port to another.
static (inside,outside) tcp 8080 X.Y.Z.2 80 netmask
! In your web browser you would have to have
Hope it helps
layhlaing Tue, 09/28/2010 - 16:20
Really appreciate for your help, Collin. Would I be able to continue my ADSM management (https) from "inside" interface? Last time, i was no longer able to do that until I undo that nat statement for DMZ. My statement might be not correct in some how. Will do and let you know.
layhlaing Thu, 10/07/2010 - 07:07
Hi Collin,
Thanks again for your time. I have managed put anti-spam server in DMZ and web server / mail server in inside network. They work correctly with NAT and PAT so is VPN. But I am having access denied for ssh connection. I can't ssh into the box from inside and dmz although I have  following:
ASA Version 8.3(1)
ASA(config)#crypto key generate rsa modulus 1024
ssh inside
ssh dmz
ssh management
ssh timeout 5
I was prompted to enter username and password but keep getting access denied. Could you please advise me with this ssh issue?
layhlaing Fri, 10/08/2010 - 07:55
Hi Collin
Please be informed that I have got SSH access after issuing following:
ASA(config)#aaa authentication ssh console LOCAL
Before issuing the above command, SSH can only be accessed with user "asa" which I cannot find anywhere in the configuration.
Anyway, thanks a lot for your sharing.
Related Content
