ICT between cucm 8.x and cucm 4.x
Answered Question
Sep 28th, 2010
Any idea whether ICT between 8.x and 4.x will work? is there any chalenges? cud u pls assist
Thanks in advance
Madan
Correct Answer by Jaime Valencia about 6 years 5 months ago
It will work, no special config or considerations.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
Overall Rating: 5 (1 ratings)
tore.skancke Tue, 09/28/2010 - 23:26
It will work yes, but be aware that if you plan to include the ICT in a route group you can't use QSIG tunnelling in the H.323 ICT. QSIG tunnelling is useful if you would like features such as call back and Message Waiting Indicators.
Tore:)
