09-28-2010 09:40 AM - edited 03-21-2019 03:04 AM
I have the uc-560 with 4 PSTN line and one GSM Gateway
The system is functioning well
I will like to allow outgoing call on PSTN and GSM gateway for some user and deny it of other
I will have 3 user group
GROUP1 : can make outgoing call on GSM gateway and PSTN line directly
GROUP2 : cannot make outgoing call on GSM gateway and PSTN line directly, Must call Standard (user X) then this user make outgoing call and forward to internal user
GROUP3 : cannot make outgoing call on GSM gateway and PSTN line directly or via the standard
How to implement it ?
Solved! Go to Solution.
09-28-2010 10:04 AM
To the best of my knowledge, CCA can configure FXO lines into groups and you can assign these groups to access codes dialed by the user community at large, but there isnt a way to partition sets of users to be allowed / denied access to these codes. You can restrict phones from dialing toll or international, so can force them to have to dial through the other users though....
Steve
09-28-2010 10:04 AM
Steve
09-28-2010 11:28 AM
Thanks for your answer
I already have the access code (the default 9)
Can I change it and use new access code like 478 ?
I don't understand your second recommendation
If i understand well, I can use it to force some user to make outgoing call through the standard user ?
How can I implement it ?
09-28-2010 11:39 AM
WHile you can select a code that is not ambigious, it will not be restricted if others learn of it.
And yes, you interpreted the call through correctly. CCA allows you to restrict users in the voice window.
09-28-2010 01:48 PM
