ASA and VPN Client for Public Internet VPN on a Stick
Sep 28th, 2010
Hello Everyone,
i follow this procedure to configure VPN for access internet through ASA : http://www.cisco.com/en/US/products/ps6120/products_configuration_example09186a00805734ae.shtml
VPN client connected with ASA and can access all inside and wan resource with no_nat. So i want VPN client can access internet through ASA with above procedure configuration, so client can not access to the internet. Subnet for VPN is 10.50.21.0/24
Attached is my configuration.Pls help me to resolve this problem.Thanks for your support time.
sinv Tue, 09/28/2010 - 10:34
Please confirm that you have configured the
same-security-traffic permit intra-interface
If this has been configured then :
* Check for the xlate entry for the specific client IP address to see if the translations are being hit.
* Also post any logs or captures that you may have collected at the time of internet access.
Sindhuja V
khangphamvu Tue, 09/28/2010 - 21:56
I'm sure i have configure same-security-traffic permit intra-interface, attached is log when users VPN and access internet. Do you have solutions for this.
Thanks for your reply.
Namit Agarwal Tue, 09/28/2010 - 22:13
  • Cisco Employee,
Please change the following in the running config  :
nat (outside_internet) 1 10.50.21.0 255.255.255.255 dns
TO:
nat (outside_internet) 1 10.50.21.0 255.255.255.0 dns
I hope this helps
Namit
khangphamvu Tue, 09/28/2010 - 22:40
You right, i have fix it and it ok,thanks for your time.
