Can the Protect Link Product be set up with a "White List?"
Sep 28th, 2010
From a partner:
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:"Times New Roman"; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi;}
I called the support line on this one but did not get a solid answer.
Q: with protectlink web protection. Can you limit all websites but 1.
I am not sure that setting the security to high and checking all 80 categories, at the same time listing 1 URL in the approved box that you can guarantee that all websites but 1 will be blocked.
Can you reach out to some one on your team to see if they can confirm if the above config would work?
Paolo Bevilacqua Tue, 09/28/2010 - 11:23
Just to begin with, which product are you talking abou?
Alos, note, since it appears you are a Cisco employee, it would be better that you go to the many internal resources available to you, this not to give the impression that your best support source in a free customers forum.
