Some agents are not able to be monitored from CSD.
I am experiencing a problem where only SOME agents are unable to be monitored from CSD.  Out of approx. 50 agents logged in, only 3 or 4 are unable to be monitored.  They are all on the same switch stack and configured the exact same way.  I have disabled advertising the G722 codec but that didn't solve the problem.  Any ideas?
By the way, I'm running UCCX 7.0 SR3.
Overall Rating: 5 (1 ratings)
Pablo Leiva Tue, 09/28/2010 - 13:38
Hi, you can check the following:
-->Check for firewall and antivirus
-->NIC compatbility
-->Run postinstall
-->Span to PC port, pc PORT enabled , PC voice VLAN access and G.722 codec disabled
-->Sniffer on agent PC to see if it is getting any RTP
Taken from Rajiv's doc:
