ISR G2 SRST to CME conversion
Sep 28th, 2010
Hi we ordered an ISR G2 2921 router with CME license,
It looks like the partner made a mistake and ordered the router with SRST license instead of CME license.
As far as I know it is not possible to convert from SRST to CME on G2 routers like we did on 2800 series.
Does any one have any idea or experience with it?
I dont have the router so I can not test it.
Mert
Overall Rating: 5 (1 ratings)
paolo bevilacqua Tue, 09/28/2010 - 12:34
  • Hall of Fame,
    Founding Member
G2s only have a single license type for voice features: UC.
So, there is nothing to convert, and CME or SRST, doen't make any difference.
mert demirer Tue, 09/28/2010 - 12:42
Thanks Paolo,
Just curious about it.
If it does not make any difference why do we need to choose one of them at the configurator ?
I know it did not make any difference with 2800 series just not sure abot the new ones. Did you have a chance to test it?
paolo bevilacqua Wed, 09/29/2010 - 04:13
  • Hall of Fame,
    Founding Member
I don't know about the configurator, however things are as I stated above.
Thanks for the nice rating and good luck!
