change the IP address of the phone
Answered Question
Sep 28th, 2010
Hi All,
Can I change the IP address of the phone? The phone is getting IP from CUCM. For some reason If i want to edit the IP address how can i do that. The edit key is disabled on the phone. My friend told me that we need to press *  to edit that. I tried but its wont works. Please adivse.
Murali.
Correct Answer by David Hailey about 6 years 5 months ago
Not knowing what type of phone you are on, the standard 79XX series phones do not use * to unlock the settings - instead, it is * * # (star, star, pound).
Hailey
Overall Rating: 5 (1 ratings)
Correct Answer
David Hailey Tue, 09/28/2010 - 17:28
Hailey
