CSS 11503 - service load - what does it mean
Answered Question
Overall Rating: 5 (1 ratings)
johnson.john Wed, 09/29/2010 - 09:18
Really....
Session Redundancy: Disabled
  Redirect Domain:
  Redirect String:
  Keepalive: (TCP-7777   5   3   5 )
  Keepalive Encryption:      Disabled
  Last Clearing of Stats Counters: 09/28/2010 07:00:23
  Mtu:                       1500        State Transitions:            6
  Total Local Connections:   5225        Total Backup Connections:     0
  Current Local Connections: 1           Current Backup Connections:   0
  Total Connections:         5225        Max Connections:              65534
  Total Reused Conns:        0
  Weight:                    1           Load:                         99
  Weight Reporting:          None
So how does 1 Local Connections translate to a load of 99?
Just trying to understand what this is telling me.
Thx
jj
johnson.john Wed, 09/29/2010 - 13:18
Ok....
I had looked at the documentation before and saw the
Load/Average Load
The current and average load for the service.
but I did not find a definition of 'load' or an association with connections or what the average load is and how is it calculated.  And then based on these  numbers, how should the load balanced nodes be weighted depending on the power/capabilities of each node - probably just a wag based on looking at the statistics on the CSS and the individual nodes.
Thanks for your help
John
