Cfwdall Off-net to Off-net
Sep 28th, 2010
I am at a loss. I still cannot forward a call off-net from an off-net call. I have checked under service manager, not blocking. Tested multiple CSS settings, everything works as advertised. I can fwd off-net from an internal number fine. What am I missing.
CUCM 7.1.5
H.323 Gateways.
Thanks in advance
Overall Rating: 3 (2 ratings)
rpomerleau Tue, 09/28/2010 - 16:56
Thanks for the pointing out.
But, this hasn't resolved my issue.
Paolo Bevilacqua Wed, 09/29/2010 - 04:16
Take, "debug isdn q931" with "term mon" and post it here.
Do not take any other debug, do not use attachments.
rpomerleau Wed, 09/29/2010 - 06:13
Below is from my incoming gateway. I have 2, 1 in and 1 out. The outbound gateway doesn't see the call.
632199: *Sep 29 08:36:04.390 ET: ISDN Se0/0/1:23 Q931: RX <- SETUP pd = 8 callref = 0x0237
Bearer Capability i = 0x8090A2
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA9838F
Exclusive, Channel 15
Progress Ind i = 0x8283 - Origination address is non-ISDN
Calling Party Number i = 0x2181, 'XXXXXXXXXX'
Plan:ISDN, Type:National
Called Party Number i = 0x80, '3017'
Plan:Unknown, Type:Unknown
632200: *Sep 29 08:36:04.406 ET: ISDN Se0/0/1:23 Q931: TX -> CALL_PROC pd = 8 callref = 0x8237
632201: *Sep 29 08:36:04.646 ET: ISDN Se0/0/1:23 Q931: TX -> DISCONNECT pd = 8 callref = 0x8237
Cause i = 0x809B - Destination out of order
632202: *Sep 29 08:36:04.686 ET: ISDN Se0/0/1:23 Q931: RX <- RELEASE pd = 8 callref = 0x0237
632203: *Sep 29 08:36:04.690 ET: ISDN Se0/0/1:23 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x8237
rpomerleau Wed, 09/29/2010 - 06:45
So after posting above I kind of stumbled on what I thought was going on. Seeing as I have 2 gateways I started checking to see if they were talking to each other. Well, my limited knowledge in that didn't come up with anything. So, for a temporary fix, I have created a new CSS, that uses a route pattern, which looks at a reversed ooutbound RG. So when a call comes in my inbound gateway, it gets turned right around and sent out the same gateway. I am going to use this as a temporary fix, but if someone can give me some insight on how to get this working properly I would be greatly appreciative.
Related Content
